Thread Number: 73649
Top Loader Extra Rinse? |
Post# 972577 , Reply# 1   12/9/2017 at 11:46 (2,329 days old) by rp2813 (Sannazay)   |   | |
We had a '97 Amana made by Raytheon, which was basically the same machine as the 432. I always had that thing set for an extra rinse. Worst rinsing of any machine I've ever owned. Towels in particular were a lost cause.
We replaced the Amana pair with a Duet pair and had increased suds levels in the Duet for a while due to non-he detergent residue in everything. Once it all had been cycled through in the Duet, suds levels normalized. |
Post# 972580 , Reply# 2   12/9/2017 at 11:55 (2,329 days old) by johnrk (BP TX)   |   | |
Why would that machine be any worse at rinsing than any other top loader? I don't understand. |
Post# 972595 , Reply# 3   12/9/2017 at 13:59 (2,329 days old) by appnut (TX)   |   | |
My 1978 GE had extra rinse option. It stayed on the whole time I had the machine. From what I understand, GE had a strike in like 1976 or 1977 and I have a feeling my machine was produced during that time. Its pump didn't sound at all like the one in my sister's or mom's washer. Mine had difficulty getting all the residual water out of the system after the spray rinse and just barely got up to full spin speed by the time it was time for it to stop to fill for the rinse. The only time it worked "correctly" was on smaller loads. Had a friend who bought the same model a year later. Hers performed like it was designed to. Then came the 1986 Lady Shredmore. Much to my dismay, there was no spray rinse on knit/delicate or normal cycles after the wash. Only after the deep rinse. Only on PP after the cool down phase did it spray after the "wash". Horrible rinsing due to lack of spray rinse after wash. Thus 2nd rinse on loads I used normal on--only towels and sheets. Everything else was washed on Knit/Delicate with wash time reset for a total of 16 minute wash. The Fridgemore also had extran rinsne turned on for all cotton cycles. The sequence after wash was a suds kill flush. Then 2 pulse spins followed by rinse. With extra rinse on it did a total of 4 rinses. My Duet was a breath of fresh air with more than adequate real rinsing. This post was last edited 12/09/2017 at 18:53 |
Post# 972600 , Reply# 4   12/9/2017 at 14:22 (2,329 days old) by Frigilux (The Minnesota Prairie)   |   | |
Extra Rinse: Only on loads using liquid chlorine bleach. Generally one load per week.
Most other loads: I fill my Speed Queen top-loader with true warm or hot water, then switch to the Normal Eco cycle which employs a spray rinse. Clothes are always rinsed adequately and water use is cut substantially. |
Post# 972602 , Reply# 5   12/9/2017 at 15:05 (2,329 days old) by rp2813 (Sannazay)   |   | |
Post# 972603 , Reply# 6   12/9/2017 at 15:25 (2,329 days old) by speedqueen (Metro-Detroit)   |   | |
Post# 972606 , Reply# 7   12/9/2017 at 15:34 (2,329 days old) by rp2813 (Sannazay)   |   | |
Exactly. That's why I'll never own a SQ TL. Fool me twice, shame on me.
Yes, they're old school with their long stroke agitation and better built than other makes, but they are far from the exalted holy grail that so many consider them to be. Anyone who is susceptible to skin irritations from detergent residue would be advised to steer clear of SQ toploaders. |
Post# 972634 , Reply# 8   12/9/2017 at 17:04 (2,329 days old) by mjg0619 (Scranton, Pennsylvania)   |   | |
No rinsing issues on my Maytag LAT7793, but you should have seen the suds cake that would appear in that machine the first time a load was put in there that had last been washed in our old DD Whirlpool. And yes, the extra rinse was almost always employed on the Whirlpool.
The Maytag does a spray rinse in the first spin, then deep rinse with 2 mins of agitation, and another spray rinse in the final spin. P.S. I'll also throw in my vote that ANY older Maytag cleans better. *ducks and runs* |
Post# 972639 , Reply# 9   12/9/2017 at 17:23 (2,329 days old) by rp2813 (Sannazay)   |   | |
Post# 972654 , Reply# 10   12/9/2017 at 18:32 (2,329 days old) by Imperial70 (MA USA)   |   | |
I think the poor rinsing issue also has something to do with the tub design.In particular the holes are not like any other perforated basket. Just a thought. I too noticed the poor rinsing, even with small dose HE detergents. |
Post# 972656 , Reply# 11   12/9/2017 at 18:35 (2,329 days old) by johnrk (BP TX)   |   | |
I didn't state that I was having any rinsing problems at all with this 432, in fact I certainly haven't noticed any. But, I'm not prone to overdosing with detergent, either. |
Post# 972667 , Reply# 12   12/9/2017 at 19:05 (2,329 days old) by washman (o)   |   | |
and usually when I wash 4 sets of bathroom towels.
However I have found that dosing the rinse with vinegar improves soap removal considerably. |
Post# 972671 , Reply# 13   12/9/2017 at 19:24 (2,329 days old) by chetlaham (United States)   |   | |
I'm useing extra rinse less often now that almost every detergent is HE by default.
Biggest bad habit for me has always been overdosing on detergent- so I have extra rinsed when it could have been avoided in the first place. SQ rinse ability- honestly, I do believe they do not rinse as well as other designs, even latter version of top loads that had a reduced spin/spray. Overall design might play a role. For example when the machine stops I do notice water comes down from the area where the balance ring meets the inner tub. Second thing I have noticed (least on my machine) is that the spin spray starts much to early, as soon as most the water has dropped below the inner basket- clothes still sopping and tub not at full speed. Its not that the drain is slow, but rather that the spray literally starts about 1 minute in when it should start at 3 minutes in according to the timer chart. On videos of the the 542, the spray does start latter. In any case I would agree that SQ washers do not rinse as well as a late model DDs for example. |
Post# 972702 , Reply# 14   12/9/2017 at 23:13 (2,329 days old) by speedqueen (Metro-Detroit)   |   | |
In my own opinion, HE detergent doesn't rinse any better than an old fashioned high sudser, you just cannot gauge it because there are near no suds from the start. The surfactants are still there, you just can't see them.
I think SQ's final spins are actually higher than Maytag if I recall correctly. The first spin being set to slow on my DOE spec AWN432 because the Permanent Press cycle has to be used instead of normal doesn't help the already poor rinsing any bit. |
Post# 972704 , Reply# 15   12/9/2017 at 23:27 (2,329 days old) by chetlaham (United States)   |   | |
Good point about not seeing surfactants. Perhaps its the suds causing it, but the water in rinse feels less "slippy" to me if that makes sense. But the biggest peice of advice I can give: Never use the scope that comes with the box of powder or the cup in liquid. We all know its the right dosage x5, often literally. Its like tooth paste, they show an entire roll of paste on the brush covering every bristle when you only need a green pea sized drop.
SQ would be (at least should be) higher than a Maytag. You are right about the first spin being slow on the 432. Yes, it certainly does not help. |
Post# 972734 , Reply# 16   12/10/2017 at 03:18 (2,329 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 972737 , Reply# 17   12/10/2017 at 05:45 (2,328 days old) by chetlaham (United States)   |   | |
Frigilux, thank you, I was not aware of this. Which its very surprising (and puzzling) to hear. Especially the spin spray being so early- I can't see the logic there. I always assumed it was a mistake in the specing of the timer or a hold over from the Amana days (the tech sheet calls for the spin/spray much latter in my 2013 model and it is identical {except for the motor cap} to a 97 Amana tech sheet), but the fact such logic has carried over to a total cycle reprogram leads me to ask why. Excluding a PP cycle, in all the washers I have seen the spin/spray starts after the water has fully left.
Post# 972786 , Reply# 19   12/10/2017 at 11:26 (2,328 days old) by Yogitunes (New Jersey)   |   | |
curious as to what causes one machine to rinse better than another....
maybe... timing of when spin/spray starts, and for how long? spin speed and time once full speed is acquired? fabric, like towels, that hold a lot more suds? machines that don't have a one-way valve on the pump, allowing remaining suds from wash, to be pumped back into the machine during rinse... also machines like a DD Kenmore....those pumps spinning backwards during agitation can whip up a lather of suds on their own... oddly enough, spin/spray rinsing...like on the Eco cycle and machines like the Cabrio have been shown to be very effective... but that could be an idea from their FL counterpart machines....rinsing is nothing more than saturate, and extract several times.....just like if you handwashed an item in the sink... |
Post# 972937 , Reply# 21   12/11/2017 at 03:09 (2,328 days old) by chetlaham (United States)   |   | |
