Thread Number: 74015
/ Tag: Modern Dryers
Gas Dryer Height Requirement in Garage 18 inches? |
Post# 977926   1/11/2018 at 19:42 (2,296 days old) by dylanmitchell (Southern California)   |   | |
I've always seen water heaters on elevated platforms but have never seen an elevated dryer. Anyone here elevated a dryer in a garage? SQ recommends 18 inches and Californi appears to require any appliance with an ignition source has to be elevated 18 inches or more. The installer and local utility company (who did free gas line check) never mentioned it and it doesn't appear to be widely followed. It does seem like a good idea to get sparking devices above the ground where fuel source fumes are likely to be.
In Southern California garage temps don't get cold enough to freeze pipes so it's common to have water heaters, washers and dryers, and utility sinks in the garage. |
Post# 977943 , Reply# 1   1/11/2018 at 23:26 (2,296 days old) by RP2813 (Sannazay)   |   | |
I never thought about this for dryers, but it makes sense considering it's required for water heaters.
Our Maytag DG806 lived in the garage and had a pilot light but I never gave it a thought. I know our 2008 Affinity dryer uses a heating element to ignite the burner instead of a spark. Maybe that's permissible without the 18" elevation? |
Post# 977973 , Reply# 3   1/12/2018 at 08:29 (2,296 days old) by mrb627 (Buford, GA)   |   | |
Post# 978004 , Reply# 4   1/12/2018 at 11:52 (2,295 days old) by dylanmitchell (Southern California)   |   | |
Thanks for the replies. Neighbors have elevated water heaters (even the electric ones) and elevated gas furnaces (for HVAC systems) but none of the dryers are elevated (including ones in the garage). Does make sense to have them elevated.
Neighbors may not be the best example though. Some store bbq and propane tanks in their garages. My bbq and propane tanks are always stored outside away from ignition sources. |
Post# 978022 , Reply# 6   1/12/2018 at 16:43 (2,295 days old) by Yogitunes (New Jersey)   |   | |
