Thread Number: 74060
/ Tag: Refrigerators
1956 Fridgidaire Imperial Cold Pantry |
Post# 978383 , Reply# 1   1/15/2018 at 00:41 (2,293 days old) by rp2813 (Sannazay)   |   | |
The evaporator fan should be tied into the cooling cycle, so it makes sense that if the thermostat is calling for cooling, everything involved in that process is operating.
I assume that when you turn the cold control to "OFF" everything shuts down. If not, then yes, there's an issue with the thermostat and it's probably not something that can be fixed.
There are universal aftermarket cold controls out there, and the best place to find them would be on ebay. You'd have to extract yours or take a good picture of it so you can compare it to what you might find on line.
I had a similar problem develop on my '57 GE Combination. The fridge would run continuously even on the warmest setting. I pulled the cold control and there was nothing visibly wrong, but I tried to take the assembly apart and it did not turn out well. There's nothing serviceable inside.
The one thing I do recall is that the NOS replacement control I installed had instructions and adaptive mounting hardware for other makes besides GE, and Frigidaire was one of them. |
Post# 978416 , Reply# 4   1/15/2018 at 07:52 (2,293 days old) by Lombardo (Woodruff, SC)   |   | |
Do you guys have advice for removing the Old thermostat? I was lucky to find and own one on eBay this morning, I see the metal tube goes up and over the inside cabinet just not sure how it comes out. |
Post# 978435 , Reply# 5   1/15/2018 at 10:38 (2,293 days old) by eronie (Flushing Michigan)   |   | |
So is the refrigerator compartment freezing anything? Could be a tired compressor... |
Post# 978449 , Reply# 6   1/15/2018 at 12:58 (2,293 days old) by rp2813 (Sannazay)   |   | |
Let's hope it's not a tired compressor. I hadn't thought of that possibility, but yes, if it's getting overly cold in the cabinet, then the compressor is likely still OK.
The tubing is probably either clipped into place, or like my '57 GE, has a couple of clasps that are held by small screws (see picture). You may need to remove the rear panel to get at the evaporator, but I'm going on fuzzy memory of what these Cold Pantry models look like. If you can post a picture of the interior, that should help.
Post# 978465 , Reply# 8   1/15/2018 at 15:13 (2,293 days old) by rp2813 (Sannazay)   |   | |
Bummer. It's hidden. If there's no way to view from the top (like below the freezer section, I'm assuming), I don't know how you'd fish through a new one. Worst case scenario would be to securely attach a line or thin wire and pull the thing out from the front end, and use that same line to pull the new one back through, but there's no telling whether you'd hit a snag trying to remove or reinstall.
Others here are more familiar with Frigidaires than I am, and may be able to provide information on the R&R process. |
Post# 978483 , Reply# 9   1/15/2018 at 17:30 (2,292 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 978638 , Reply# 10   1/16/2018 at 22:04 (2,291 days old) by Lombardo (Woodruff, SC)   |   | |
Update... I don’t think it’s the thermostat. I purchased a temporary thermostat and wired it in. I’m getting the same results with the temporary thermostat. So is it the relay stuck with the contacts closed? |
Post# 978640 , Reply# 11   1/16/2018 at 22:11 (2,291 days old) by Diesirae7 (Central Illinois)   |   | |
check the relay out, something is fused together there. |
Post# 978655 , Reply# 12   1/17/2018 at 00:52 (2,291 days old) by PhilR (Quebec Canada)   |   | |
The fan for the cold plate in the refrigerator section of these fridges should run most of the time and shut off when the temperature in the refrigerator section gets cold, the thermostatic control for this fan is usually hidden somewhere behind the plastic trim around the liner. It should run with the main control in off position and when the door is open too. At least, it's how it is on my 1959 and 1961 Frigidaire Frost-Proof refrigerators.
If the compressor runs continuously with any setting of the thermostat except the "off" position, the freezer section should get below 0°F. If that's what it does, then the thermostat might be the problem... I'm not sure about the YT relay, never had a problem with any of mine. Here are a few pictures from a service manual. I don't have the complete information for 1956 models but I hope that helps. This post was last edited 01/17/2018 at 01:11 |
Post# 978733 , Reply# 13   1/17/2018 at 16:50 (2,290 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 978774 , Reply# 14   1/17/2018 at 21:33 (2,290 days old) by Lombardo (Woodruff, SC)   |   | |
It’s clipped to the cold plate. I’m thinkjng the relay is fused I was lucky to find a new old stock relay and should arrive in a couple days so I am crossing my fingers. |
Post# 979084 , Reply# 15   1/19/2018 at 23:33 (2,288 days old) by Lombardo (Woodruff, SC)   |   | |
How do slide the inside cabinet out to route the thermostat through? The string broke when installing the new thermostat. Now I’m forced to do it this way. Any advice is appreciated. |
Post# 979100 , Reply# 16   1/20/2018 at 02:06 (2,288 days old) by rp2813 (Sannazay)   |   | |
So did it need the new thermostat after all? How did you determine that? Just curious.
Can you use something like a length of coat hanger wire instead of a string? If that will push through to the rear opening, you should be able to pull the capillary tubing behind it. How you keep it attached to the wire is the tricky thing.
Removing the liner could be a big job, but it can certainly be done. I wonder what a repair tech would have done back when these refrigerators were daily drivers in homes across the nation. I can't imagine it would have been a lengthy process to replace this part. |
Post# 979151 , Reply# 18   1/20/2018 at 12:36 (2,288 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 979153 , Reply# 19   1/20/2018 at 12:53 (2,288 days old) by Lombardo (Woodruff, SC)   |   | |
I’m glad it worked too I didn’t want to attempt removing the liner. The only thing is even with the new relay and thermostat it’s not cycling yet. Keeping my fingers crossed because I don’t know what to do next.? |
Post# 979157 , Reply# 20   1/20/2018 at 13:25 (2,288 days old) by rp2813 (Sannazay)   |   | |
Give it some time. I don't know if there are system design quirks on these refrigerators that may cause them to operate differently from other makes. For sure if yours is working at bringing the cabinet temperature down to the 37-40 range, it could run for a while.
Do you have the cold control on the warmest setting? That would be a good way to determine whether there's another problem, although I can't imagine what else would cause the compressor to keep running if both the thermostat and relay have been replaced. Do you hear a click when you adjust the cold control lower or higher? That would indicate that the contacts are opening and closing properly.
Perhaps it's a wiring issue. Do you know whether anyone has messed with the relay or thermostat before? |
Post# 979356 , Reply# 21   1/21/2018 at 16:39 (2,286 days old) by RP2813 (Sannazay)   |   | |
Post# 979522 , Reply# 23   1/22/2018 at 23:50 (2,285 days old) by RP2813 (Sannazay)   |   | |
Post# 979581 , Reply# 24   1/23/2018 at 13:34 (2,285 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 979705 , Reply# 25   1/24/2018 at 11:20 (2,284 days old) by Lombardo (Woodruff, SC)   |   | |
Update I talked to a refrigeration repair guy. He asked if frost was on the cold plate. There isn’t any frost so he says the system is low on Freon. He is coming out to recharge it tomorrow with Freon 12 replacement. He says that’s what will fix the problem. |
Post# 979724 , Reply# 26   1/24/2018 at 13:57 (2,284 days old) by RP2813 (Sannazay)   |   | |
Interesting that it can still get below freezing inside and yet the evaporator accumulates no frost, but it does make sense that with the evaporator not getting cold enough, the thermostat registers that the machine needs to keep running.
Let us know how it goes after the recharge, and let's hope the refrigerant leak is a very slow one. Freon is not cheap, nor is it good for the planet to release it into the atmosphere at any rate. |
Post# 979737 , Reply# 27   1/24/2018 at 15:52 (2,284 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 979741 , Reply# 28   1/24/2018 at 16:23 (2,283 days old) by ken (NYS)   |   | |
If the leak is very small it could take years for it to leak enough after the recharge to cause the problem to surface again. But if its larger it may be a good idea to add dye to the Freon so the leak can be easily seen. That's done often to find leaks in auto a/c systems. Id run this idea by the refrigeration guy when he comes to recharge it.
Post# 979746 , Reply# 29   1/24/2018 at 16:31 (2,283 days old) by RP2813 (Sannazay)   |   | |
Post# 979976 , Reply# 30   1/26/2018 at 08:59 (2,282 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
If it doesn't freeze to the end of the evaporator(s), it's either low on gas or has a weak compressor. The tech will know which is the problem the moment he breaks into the low-side and puts a gauge on it. |
Post# 980287 , Reply# 32   1/28/2018 at 17:51 (2,279 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The fan on this model is supposed to run whenever it’s plugged into the wall thermostat the relay etc. do not control the fan motor operation.
The real question here is whether the refrigerator is keeping the proper temperatures in each compartment, and the compressor should shut off periodically, you may not see frost on the evaporator especially the humidity is fairly low. What are the temperatures in the refrigerator and freezer section currently. John L. |
