Thread Number: 74185
/ Tag: Modern Dishwashers
Comfort Lift Dishwasher |
Post# 979680 , Reply# 1   1/24/2018 at 09:40 (2,283 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
I've seen that a while ago indeed. It looks very convenient, but there are a few downsides. This system takes up space in the bottom rack. It's also in the way when you want to pull out the upper drawer, so if you are used to having both drawers open, it's a bit of a PITA. It's also in the way for reaching the salt container and the filter.
Aside from this all, I read in the test from the Duth consumer organisation that this dishwasher isn't very good at keeping itself clean. I'm not very keen on later AEG dishwashers anyway. |
Post# 979698 , Reply# 2   1/24/2018 at 10:49 (2,283 days old) by speedqueen (Metro-Detroit)   |   | |
Post# 979758 , Reply# 3   1/24/2018 at 17:38 (2,283 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 979771 , Reply# 4   1/24/2018 at 18:25 (2,283 days old) by appnut (TX)   |   | |
That one-handed mechanism reminds me of what's used to raise/lower my upper rack on my Kenmore Elite. Am I to assume the ComfortLift feature isn't option such that one can select to slide the bottom rack out onto the door rather than lift it up if you so choose? If it would allow that, then gives the flexibility of loading such as Luigi pointing out you have to slide the racks in and out depending upon whether you want to load the bottom or top rack. |
Post# 979772 , Reply# 5   1/24/2018 at 18:26 (2,283 days old) by appnut (TX)   |   | |
Post# 979774 , Reply# 6   1/24/2018 at 18:42 (2,283 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
