Thread Number: 74349
/ Tag: Vintage Dishwashers
Damsel in Dish-tress [ KDS-21 ] |
Post# 981342   2/5/2018 at 08:21 (2,272 days old) by PamK (Lenox)   |   | |
Oh happy day. Oh woah is me.
I had my Kitchenaid KDS-21 installed on Friday. But, it wouldn't start. The plumber replaced the original hard-wire with a cord. Could that be the issue? Any super expert near me who might be able to help me troubleshoot? I live in Western Massachusetts. I write a midcentury homes on my blog, more info in my story today. Many thanks, automaticwasherites! CLICK HERE TO GO TO PamK's LINK
Post# 981343 , Reply# 1   2/5/2018 at 08:31 (2,272 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Welcome.
Glad you're enjoying the site. It sounds like there could be a power issue between the cord or the outlet. It could be the micro switch on the top right of the door. When you gently close it do you here a click ? And also, is there a little rubber pointy thing on the top right where the activation (safety) switch is ? Where did you get the machine from ? There are quite a few experts here that will be chiming in shortly. I hope you get this sorted out soon. Last of the Good KitchenAids. |
Post# 981344 , Reply# 2   2/5/2018 at 08:32 (2,272 days old) by ken (NYS)   |   | |
Post# 981347 , Reply# 3   2/5/2018 at 08:54 (2,272 days old) by PamK (Lenox)   |   | |
@toploader aka lifesaver (I hope),
Indeed, a little rubber pointy thing had BROKEN OFF from somewhere when my plumber friend got going. We didn't know what it was. But howdy hudee, I kept it, and I actually found it easily. I see where you say it goes. What do I do now? Glue it back on? What kind of glue should I use? Thank you!!!! |
Post# 981349 , Reply# 4   2/5/2018 at 09:15 (2,272 days old) by panthera (Rocky Mountains)   |   | |
You'll need a new one, ultimately - but for now, some glue will get you going. If a bit of super glue doesn't do it, try the 1 minute epoxy they have at Walmart or The Home Depot. An expert will, no doubt, be along in a minute to tell you the exact part number and where to get it cheapest. Whirlpool (who now own KitchenAid) lists it as: Whirlpool OEM Part #4172040. These were the last of the really good KitchenAid dishwashers, you will love it.
Post# 981368 , Reply# 5   2/5/2018 at 11:51 (2,272 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Ah-HA !!!
That would be the reason why it won't start. As panthera said... I'll bet the ranch it should fire right up once you glue it on. Attached are pics of my KDS 20. 1st pic is the Rubber activator. (I think the rubber is better as they don't snap off that easily. 2nd pic is the door. That little silver circle (at the top right of the door) is the switch that the "pin" pushes to start the machine. This is the safety if you open the door while the machine is on will stop the action. You could latch the door (open) select let's say Normal wash, then gently push a screwdriver in and the machine should activate. |
Post# 981372 , Reply# 6   2/5/2018 at 12:15 (2,272 days old) by RP2813 (Sannazay)   |   | |
Post# 981534 , Reply# 7   2/6/2018 at 08:44 (2,271 days old) by panthera (Rocky Mountains)   |   | |
Has a good point - JBWeld could even be used to cast an entire new piece. I always try to fix these things in a particular order - super glue, 1 minute epoxy for the simple reason that they can be removed very easily if they fail or the part is replaced. Given the clean break in your pictures, you might want to go for a much more solid connection like JBWeld. |
Post# 981553 , Reply# 8   2/6/2018 at 09:13 (2,271 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 981624 , Reply# 9   2/6/2018 at 11:39 (2,271 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
from a regular reader and occasional commenter, who loves what you do!
SteveT in FL is our resident Hobart/KA expert, and there's little he can't solve when it comes to our wonderful d/washers. We have a KD 17 Series ('71 to 76 ish) in storage for our retirement house. Enjoy your "Hurricane in a Box" and welcome! RAnderson Roger |
Post# 981632 , Reply# 10   2/6/2018 at 11:56 (2,271 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
which is important in a vintage machine of any kind (some even do it with cars!), is to find a parts machine, they're out there and usually very cheap or free. Many important parts such as motors are shared by all models within the same Series (20) but some, like timers, are unique. We had 3 different models in storage at one time, down to just one now, plus a box of spare parts!
Post# 981638 , Reply# 11   2/6/2018 at 13:16 (2,271 days old) by PamK (Lenox)   |   | |
Hi @toploader and other new BFFs:
YES: I found the white rubber pointed pin thingy and super glued it. The glue held. Meanwhile, I bought a spare on ebay -- thanks, @panthera! YES: It turned on! Dancing the kitchen time! I just finished reading the use booklet. For once in my whole life, I read the darned book. YES: I'm running it. I'm running the normal cycle. So far it's made it through load water and heat water and right now it's running the first wash. Fingers crossed! I am making a video to put on the blog. Wish me luck. I also have a few more technical questions, which I will come back with. Oh and that's a great tip @firedome -- I'll start looking for a parts machine right away. DH will be thrilled *not* to have that in the garage with all my other *projects* THANK YOU, ALL, SO MUCH !!!! |
Post# 981642 , Reply# 12   2/6/2018 at 13:45 (2,271 days old) by panthera (Rocky Mountains)   |   | |
Post# 981650 , Reply# 13   2/6/2018 at 14:58 (2,271 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 981745 , Reply# 14   2/7/2018 at 13:07 (2,270 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
Post# 1139297 , Reply# 16   1/14/2022 at 06:57 (833 days old) by chachp (North Little Rock, AR)   |   | |
I think this is the one you need but I'd feel better if one of the experts confirmed.
https://www.ebay.com/itm/275048395271QUE... |
Post# 1139302 , Reply# 17   1/14/2022 at 08:07 (833 days old) by steved (Guilderland, New York)   |   | |
I think either one might work but this one lists the original part # 116100 CLICK HERE TO GO TO steved's LINK on eBay |
