Thread Number: 74423
The AWN 432 Arrived Today |
Post# 982271 , Reply# 5   2/11/2018 at 08:13 (2,266 days old) by chetlaham (United States)   |   | |
Post# 982288 , Reply# 7   2/11/2018 at 10:14 (2,266 days old) by angus (Fairfield, CT.)   |   | |
My 432 has an "extra large" setting which is what I used - but the water still only came up to just below the second set of holes. |
Post# 982325 , Reply# 8   2/11/2018 at 14:56 (2,266 days old) by mrb627 (Buford, GA)   |   | |
Both of the electronic machines, 8 and 9 series, have a full tub fill. The knob controlled 432 fills to about 2 inches shy of the top. This is because the eco cycle fills to the water level switch with cold water. Shortly after agitation begins, the water will come back on at the requested temperature to bring the level up another inch or so.
You can adjust the water level switch to fill to the rim, just be advised the normal eco cycle will potentially overflow. Malcolm |
Post# 982397 , Reply# 9   2/11/2018 at 21:17 (2,266 days old) by harleybadger (Pittsburgh, PA)   |   | |
And it should be pointed out that if you adjust the fill on an 8 or 9 series, and even just barely turn the screw, it can fill TOO high and it will cause an error, at which point the machine will simply stop, drain and spin, and sit there. Yup, I tried. LOL. |
Post# 982409 , Reply# 10   2/11/2018 at 22:05 (2,266 days old) by chetlaham (United States)   |   | |
Malcom, why do you say this will cause the machine to overflow? The added water is is run through the overfill (second) pressure switch. If the main switch is set to fill to the top, most likely it will satisfy the over fill first or at the same time as the main switch. When that happens the machine simply will not fill for the selected temp on the normal ECO cycle.
If the OP has this second pressure switch and its wired the same (I assume it would be if its there) then the water can be raised without issue. |
Post# 982410 , Reply# 11   2/11/2018 at 22:07 (2,266 days old) by chetlaham (United States)   |   | |
Post# 982727 , Reply# 14   2/14/2018 at 00:38 (2,263 days old) by chetlaham (United States)   |   | |
