Thread Number: 74584
When is the last time you've seen one of these? (BD stack) |
Post# 983778   2/22/2018 at 00:05 (2,255 days old) by speedqueen (Metro-Detroit)   |   | |
The ad says GE(wrong!) but it is obviously based on a BD Whirlpool portable mechanism.
Does anyone know much about these? When and how long were these made, etc. Being small is it safe to assume that these were some of the first machines to switch to DD? CLICK HERE TO GO TO speedqueen's LINK on Detroit Craigslist |
Post# 983807 , Reply# 1   2/22/2018 at 06:06 (2,255 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 983811 , Reply# 2   2/22/2018 at 07:10 (2,254 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These came out in 1983, they used the compact washer mechanism that went into production in 1972 and the compact dryer design that WP started building for Sears around 1969.
These BD TTs were changed over to the DD washer style in 1987 around the time that WP changed all their TL washers over t the DD design.
Hi Richard, the one you found in the picture is the 2nd model WP produced, the first had only timed dry settings on the timer [ we have one with only timed dry settings in the museum ] These BD compact washers were fun and effective with their nearly 900 RPM spin speed.
Post# 983819 , Reply# 3   2/22/2018 at 08:45 (2,254 days old) by Tomturbomatic (Beltsville, MD)   |   | |
WP made these with the faster spin speed knowing that most of these would be paired with 120 volt dryers so they were trying to speed up the drying process with the better water extraction. |
Post# 983885 , Reply# 4   2/22/2018 at 17:55 (2,254 days old) by chetlaham (United States)   |   | |
Post# 983922 , Reply# 6   2/22/2018 at 23:01 (2,254 days old) by StrongEnough78 (California)   |   | |
Post# 983946 , Reply# 7   2/23/2018 at 06:46 (2,254 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These are fairly easy to service machines without moving them out of the closet etc. One piece stack laundry appliances like these are generally much more serviceable, easier to install and more stable in operation than when you stack two separate machines. I work on at least 5 of these machines every week.
To service the washer in the 24 and 27" WP built TTs you first remove the slanted transmission panel below the dryer, then remove the washers top and take out a few screws and remove the complete front of the washer.
Now you can easily access the water pump, drive coupling or belt, inlet water valve, motor on the DD models etc. For more serious repairs you remove two 1/2" bolts and the whole washer assembly can be easily pulled out of the cabinet to work on or replace clutches, transmissions etc.
The drive mechanism from the faster spinning BD 24" machines cannot be easily adapted to the full size BD WP washers. I have been involved with several attempts to make standard BD WP washers spin faster. When you get up to a decent spin speed of around 700 RPMs the machine will walk all over the place, My friend Bob in Cleveland has one now that he literately had to bolt to the floor. The suspension design of standard WP BD washers while very rugged and generally trouble free was just not designed to contain and control vibration well at spin speeds above around 550 RPMs.
Post# 987952 , Reply# 8   3/24/2018 at 17:20 (2,224 days old) by electronicontrl (Grand Rapids, MI)   |   | |
