Thread Number: 74753
/ Tag: Vintage Dishwashers
Detaching KD-17 panels? |
Post# 985685   3/7/2018 at 11:36 (2,241 days old) by kate (California)   |   | |
How can I detach and remove the "wrap-a-round" front panels from a KD-17? I see a couple of screws on each side of the interior. Similarly, how to detach the lower panel. Thanks.... Kate |
Post# 985721 , Reply# 1   3/7/2018 at 19:27 (2,241 days old) by rp2813 (Sannazay)   |   | |
Post# 985732 , Reply# 2   3/7/2018 at 20:00 (2,241 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
To remove the upper door outer panel open the door and remove the four small Philips head screws, if the panel does not fall off close the door and pull it off by pulling out at the bottom.
To remove the service panel and toe-kick panel remove the two Philips head screws from each panel, after taking the two screws out of the lower edge of the service panel pull the bottom out then pull the panel down to release it from the top clips.
Post# 985778 , Reply# 3   3/8/2018 at 03:28 (2,241 days old) by kate (California)   |   | |
Thank you, John. Are these the screws on the top of the door? Kate |
Post# 985808 , Reply# 4   3/8/2018 at 09:10 (2,241 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 986113 , Reply# 6   3/10/2018 at 19:12 (2,238 days old) by kate (California)   |   | |
All done! Thanks for your help, John. The service panel was attached to what I would call a chrome bumper, and they came out together. Behind that and the wheels there really is a toe-kick. Kate |
Post# 986125 , Reply# 7   3/10/2018 at 20:59 (2,238 days old) by rp2813 (Sannazay)   |   | |
