Thread Number: 75499
improving the new SQ design.. |
Post# 993342 , Reply# 1   5/6/2018 at 23:40 (2,180 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I'd like to see a circulation pump with powerful jets on the sides for a jacuzzi like effect as well as a shower recirculation in conjunction. |
Post# 993351 , Reply# 2   5/7/2018 at 00:24 (2,180 days old) by tolivac (greenville nc)   |   | |
Forget that design-start from scratch.Or at that rate SQ should forget TL machines altogether and go to FL. |
Post# 993371 , Reply# 3   5/7/2018 at 06:43 (2,180 days old) by neptunebob (Pittsburgh, PA)   |   | |
Hopefully, the agitator and the tub are not bolted together and somehow, they can be separated by concentric shafts (think a solid rod inside a hollow tube, the rod to the agitator and the tube to the tub) and some way to make it so it agitates in wash and engages the tube to the motor to spin. The motor could be programmed to agitate in different ways, like 60 deg, 120 deg, and even the 210 degrees. They could even call it Arc-cu-ate again. This arrangement just has to work better than what they have. Oh, and bring back (and lower the price) of the FL too.
Post# 993463 , Reply# 6   5/7/2018 at 20:22 (2,180 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 993543 , Reply# 8   5/8/2018 at 16:41 (2,179 days old) by DADoES (TX, U.S. of A.)   |   | |
Early Oasis & Cabrio & Bravos models used the SmartDrive design with whatever modifications WP may have done. The motor is engineered to reverse, works nicely. Search for "Dean's Washer Videos" on YouTube. He has a lot of F&P action, including a comparison of four selected agitation profiles at different water levels. Most of the agitation profiles vary in reaction to the load, occasionally a longer or shorter stroke in one direction or the other. |
