Thread Number: 75500
Maytag Neptune 3000 won't complete final spin... |
Post# 993388 , Reply# 1   5/7/2018 at 09:50 (2,181 days old) by IowaBear (Cedar Rapids, IA)   |   | |
My newer Neptune (6500) exhibited the same behavior and eventually would give up and display a "LR" code. I researched the problem and it was most commonly fixed by replacing the motor control board.
So I took a chance and just bought a used one from ebay for something like $60 or $70. Super easy repair (just swapped the boards) and it solved the problem.
There are a lot of revisions to these boards, you have to make sure you get one that is right for your machine. |
Post# 993389 , Reply# 2   5/7/2018 at 09:53 (2,181 days old) by DADoES (TX, U.S. of A.)   |   | |
There are two microswitches in the door lock mechanism. One confirms the door is closed (and operates the interior light), the other confirms the lock is engaged. It won't go into full-spin unless both switches are triggered. The door locks/unlocks slower because it operates via a wax motor instead of a solenoid. A common failure is the wax motor goes bad (doesn't lock) and blows a triac(?) on the cycle controller board in the console. A fellow online offers a DIY kit which includes an updated-style wax motor, a replacement triac, and instructions. Any 3000/4000 model still with the original-style wax motor should have it replaced ASAP with the updated wax motor (which is less-prone to the problem) before the problem occurs. Since you say the door does lock, maybe the associated microswitch is bad? 5500/6500/7500 use a solenoid-operated door lock instead of the wax motor and aren't subject to the wax motor issue ... although other door-lock related problems can occur. I'm not sure when the change to solenoid-lock occurred, maybe some 4000s had it toward end of their production. |
Post# 1003927 , Reply# 4   8/17/2018 at 07:07 (2,079 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1003983 , Reply# 5   8/17/2018 at 20:58 (2,078 days old) by Dustin92 (Jackson, MI)   |   | |
I'm now wondering if maybe the door was just out of alignment.. I tried it today and with no modification or input on my part it worked perfectly twice. I'm going tp start cleaning it up and run a few loads through to see where we are at. |
Post# 1004671 , Reply# 7   8/24/2018 at 09:09 (2,072 days old) by Whatsername (Denver, CO)   |   | |
