Thread Number: 75556
/ Tag: Modern Dishwashers
New 2018 KitchenAid DW; KDTE304GPS |
Post# 993741   5/10/2018 at 11:00 (2,178 days old) by johnb300m (Chicago)   |   | |
Hello all,
This is a bittersweet post. As many know, I was a proud owner of a GE PDT720 dishwasher, that has a very long thread of its own, when I bought my house. I'm annoyed to say, the GE has not held up in the test of time, in what was really moderate use; about 1-3 loads a week. Upon some close inspection about a month ago, I found that the pump motor had been leaking enough to leave a rather large stain on the drip pan over time. In addition to it needing a new upper spray arm last year, and after finding a split plastic weld on the lower X arm, I needed to epoxy it shut. And then 3 weeks ago, I started discovering rack rust far more advanced that is normal on a 3 year old machine IMO. In addition, the stainless front has been more difficult to keep clean than the SS on my Maytag and WP oven and fridge. All these things coming to a head, I've decided to let go of it, do what I should've done at first. Not get swayed by GE's bottle jets and reversing sprays, but cross-shopped more when I was originally looking. I mean, the Profile series DID have very good washing reviews. And it has performed very well over this time. But sadly, the durability is just NOT there. And that was even more apparent when I started shopping KitchenAids this past week. For the happy news! I was offered a deal I couldn't refuse from a local KA MT WP house on a shiny, new KDTE304GPS. Info here: www.kitchenaid.com/shop/-... It's got many of the same features as the outgoing GE, but with substantially better Fit and Feel. And a better reputation too. The racks have a much thicker coating on them, so rust should be a non-issue. The "door twist" test was nigth and day with the KA being stiffer, with a much nicer engaging door lock. KA has coated their stainless steel to make it impervious to fingerprints, smudges, water marks etc. It keeps the bottle jets I love, and adds a 3rd upper utility rack. Nevertheless I'm quite excited. It arrives on Monday! Much more to come :) |
Post# 993808 , Reply# 1   5/10/2018 at 17:23 (2,178 days old) by appnut (TX)   |   | |
Post# 993926 , Reply# 2   5/11/2018 at 23:08 (2,176 days old) by lakewebsterkid (Dayton, Ohio)   |   | |
Enjoy the new machine! Please give us updates as you "break her in"! I have grown to love the 3rd rack in my Bosch. The bottle jets are a great feature. |
Post# 993941 , Reply# 3   5/12/2018 at 03:04 (2,176 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Does this dishwasher have an alternating wash system or do they run at the same time? |
Post# 993959 , Reply# 4   5/12/2018 at 08:29 (2,176 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 994030 , Reply# 5   5/12/2018 at 20:26 (2,176 days old) by appnut (TX)   |   | |
Post# 994032 , Reply# 6   5/12/2018 at 21:23 (2,176 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Appnut, cleaning the filter is not a dreadful thing. |
Post# 994335 , Reply# 8   5/16/2018 at 00:52 (2,172 days old) by Johnb300m (Chicago)   |   | |
I got the 304 installed last night, and tonight it's loaded up, and running its first wash!
First off, This thing was a veritable dream to install. I'm new to WP machines, so this was a new experience. It's as if their engineers actually thought about how I would set it up. From the rear wheels that have 5 preset levels, to the front legs with plastic hex caps that don't mar the floor while I adjust them. Or the hex screws on the front legs with ample clearance for me to use a socket wrench to adjust them. The water valve is seated with the inlet horizontally, so I can actually use a wrench to tighten it, instead of the 2 vertical inches allotted on the GE, which took a million .5 degree wrench turns to tighten that valve. The insulation is actually hooked to the rear of the tub, so it doesn't roll over upon cabinet insertion. My FAVORITE PART; the power box was fully removable so I could wire up everything with plenty of hand space out from under the machine. Once it was all wired up, I closed it, and just screwed it back underneath. Done. No cuts. No blood. I did however not enjoy the cheap, annoying squeeze clamps. I swapped those out for actual worm gear clamps. Honestly, everything about the install was a breeze, and almost quite pleasant. All except my crappy counters and cabinets. They will not allow the machine to sit flush, or even square. But I'll have to stomach that till the remodel. Tonight it's doing it's first load. Normal, Heat Dry, with a Cascade Complete pac. It did a quick 3min. PreRinse, then right to the main wash. It then did 3 full rinses at the end, since this was the first full cycle, in order to calibrate the optical sensor. Loading the machine was pretty good. The top rack is a freakin' dream compared to the GE's pretty garbage top rack. However, WP refuses to cant their tines on the bottom rack for plate edges to recess into, so my earthenware plates fall over now. That was the only thing GE got right, was accommodating chunky plates. Everything else is great. The top rack really fits bowls and glasses nicely. Spoons and knives are out of the way now in the nifty 3rd rack. Here's the part that will blow your socks off. The little "pond pump" runs so quiet. NO motor noise! I HATED the high pitched whine from the brushes on the GE motor. The encapsulated synchronous motor is practically silent. And no bearings to leak! Yay. YET. Dang does it throw a punch. For a mere 35 watts, the bottom jets were so forceful, they were "klanking" the steel tub as they went around, shooting all the way to the top. And the upper sprays were battering the plastic containers in there. The amount of force and pressure this machine washes with; it is exceedingly surprising. Yet it's discernibly more quiet than the GE, which is weird cuz they were both rated at 48db. When the fridge kicks on, the dishwasher noise virtually disappears. This is going to be a fun machine to have and to play with. We shall see the results in the morning. In the meantime, enjoy the first few photos. :) |
Post# 994355 , Reply# 9   5/16/2018 at 08:34 (2,172 days old) by drhardee ( Columbia, SC)   |   | |
I'm sorry to hear about your problems which ultimately led to the decision to drop the GE Profile DW. The GE PDT845 Profile unit that I installed about a year and a half ago is still trundling along with no major or minor issues, other than door flex, which has led to my having to check to make sure the door is closed completely prior to starting to wash. I purchased a 5-year extended service plan through Assurant for $125.00, so I'm hoping that I'm in good stead for at least that long. GE still sells that model, but I noticed that they did change the wash arms; they're no longer the "X" pattern that I have in mine. |
Post# 994360 , Reply# 10   5/16/2018 at 09:55 (2,172 days old) by johnb300m (Chicago)   |   | |
Thanks and best of wishes with your GE, Drhardee.
Even though my experience went south, the GEs are quite capable machines, and there are a few aspects of it I will miss. That nice warranty on it is great peace of mind. It's certainly news to me that they changed up their x-arm design? Do you know what the new design is? The x-arms are still all over their website. As for this morning's results? Everything looks clean! It got rid of the starch/salt lines on my pasta pot. The nested plates looked great. No gook where they touched. The glasses were spot and grit free. Even the tall one I put in the corner! If anyone remembers, the corners were a serious Achilles heel in the PDT720. Only one of the wooden spoons in the 3rd rack had a tiny fleck of red sauce on it that was easily flicked away. One of the selling features to me on the GE was the fan assisted dry. KA has that but higher up in the models. This one has the standard dry system, ventless but with the heater coil. The tub was covered in moisture but interestingly, everything else was bone dry. Even the plastics and woods! It wasn't a very dirty load but I was impressed. All the filters are spotless as well. |
Post# 994525 , Reply# 12   5/18/2018 at 10:16 (2,170 days old) by Johnb300m (Chicago)   |   | |
Last night was a good representative load since I did some cooking.
A good mixed load from plates to cookware to wine glasses. What I was especially impressed with was that my ceramic skillet came clean. Something the GE would never do 100%. There was always some kind of film left in it. Not in the KA! Even the spatula I had with seared fish crust on it, came clean in the 3rd rack. It was set on ProWash, air dry, with the sample of Cascade Platinum they provided. Even on air dry, everything but wood spoons and a few plastic lids was perfectly dry the next morning. Interesting note, this wash sensor system seems very tolerant of soils. It did one brief prerinse and went right to the main wash. The GE would add prerinse after prerinse. |
Post# 994851 , Reply# 13   5/21/2018 at 18:41 (2,167 days old) by Johnb300m (Chicago)   |   | |
Haha!
I’ve queued up a peanut butter shmeared glass in the KitchenAid. I have more favorable expectations in this machine than the other GE that had weak corner performance.
Post# 994873 , Reply# 14   5/22/2018 at 00:15 (2,166 days old) by johnb300m (Chicago)   |   | |
A few surprises.
The first one was how short the dry cycle actually was. It was no more than 15 minutes; I was surprised when the machine beeped. I opened it up and everything was surprisingly dry. The setup. I decided to use the ProWash (sensing) cycle, with Hi Temp Wash, and Bottle Wash (for my kettle). Detergent was a Cascade Platinum pac. I added a bonus (depicted below) very dirty frying pan to the mix. Just to make it challenging. Haha. Aaaaaaaand, there was some peanut butter left behind, but it wasn't all that much. It seems like the inner-most wall of the glass, how it was placed in the rack, just didn't get strong enough water velocity to push that pb out, but a vast majority of the glass came completely clean. More importantly, EVERYTHING else was spotless. Including that stainless pan! Honestly, my stainless cookware has never looked better, than coming out of this machine. No redeposit anywhere. And NO peanut butter smell anywhere either. The cycle sequence ended up being: Brief PreRinse, Purge, PreRinse, Purge, Long Main Wash, Purge, Purge/Rinse Combo, Long Final Rinse, Short Heat Dry. The filter cup was practically spotless, save for a tiny yibble of broccoli. This is quickly turning into my favorite dishwasher of all time. |
Post# 994885 , Reply# 15   5/22/2018 at 05:22 (2,166 days old) by appnut (TX)   |   | |
John, I'm so thrilled you are so pleased with this dishwasher. the numerous purges is a significant difference between the filtered and Clean Water Wash system design. Mine only does a purge between main wash and final rinse on extremely lite soiled loads as well as China Gentle. All other cycles yield me two and sometimes three post-wash rinses. What is a purge/rinse combo? I wonder if bottle jet would completely clean a pb glass. Never known mine to have a 15 minute dry either. |
Post# 994916 , Reply# 16   5/22/2018 at 11:00 (2,166 days old) by johnb300m (Chicago)   |   | |
Thanks Bob!
It's really been an impressive few weeks with it. I mean, the GE was "pretty good" and even surprised me a few times. But this KitchenAid is just a tick ahead of everything. Every load thus far seems to be an extra level of clean. And the KA does a marvelous job keeping itself clean too. The purge/rinse combo was interesting. It did a partial fill. But more than a regular purge. And less than a full fill. Enough to wash the lower level at full pressure for about 30 seconds. Then it washed the upper level, with some cavitation, but in several "bursts" and pauses. Then it drained. The whole thing lasted about 1min. Then it filled for a final heated rinse that was almost as long as the main wash. The behavior of your CleanWater system, Bob, makes sense to me. That spinning filter never gets caked with crud, so it can probably get away with not bothering with cleansing purges. Whatever WP has figured out, their soil management is impressive. I've yet to find any grit, anywhere in the machine. Judging by how little pb was left in the far corner, I'm fully confident that glass would've been fully clean somewhere else. Bottle jets or not. :) That pan still blows my mind. |
Post# 995019 , Reply# 17   5/23/2018 at 15:10 (2,165 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
When the spray arms alternate, do they speed up and slow down? My dad's new Kenmore does. |
Post# 995070 , Reply# 20   5/24/2018 at 10:53 (2,164 days old) by johnb300m (Chicago)   |   | |
1. No, GELaundry, the arms seem to run at consistent speed and pressure upon a full fill charge.
2. Lakewebster, correct me if I'm wrong; Bosch pleats their metal mesh filter cup? I wonder if that pleating may inhibit some of the self cleaning water turbulence. What I've noticed helps a lot in the WP Global Wash is the pump inlet is baffled, preventing direct suction against the screen. The GE layout currently in use, has the pump inlet un-shrouded, directly sucking against the screen. Dirt would collect there all the time, and never really release during multiple drain sessions. 3. The discussion on full rinses vs. purges and light splashes is interesting. I've now had direct experience with two brands displaying the differences of both techniques. The GE would do all full pre and post rinses. In fact, at times it would do as many as FIVE pre-rinses. The KA will do far less full rinses, but it does a lot of purges and "splashy" partial fill rinses. I'm not sure if it comes down to filter system efficiency? Because KA has pulled off the feat of rinsing off more silt with less resources than the GE ever did with far more water. Maybe those purges get rid of a lot of residual silt and soil, preventing it from circulating around in all those full rinses? |
Post# 995097 , Reply# 21   5/24/2018 at 15:48 (2,164 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Why do some whirlpool dishwashers have their spray arms spin faster during the middle rack arm operation after alternating? |
Post# 995159 , Reply# 22   5/25/2018 at 09:14 (2,163 days old) by johnb300m (Chicago)   |   | |
No idea.
But your model, if remembering correctly, has the Kenmore version of the TotalCoverage spray arm on the bottom, which has the shifting spray pattern. That will speed up and slow down based on the pattern its in. There's no reason the middle arm should be changing speeds unless it's malfunctioning. |
Post# 995161 , Reply# 23   5/25/2018 at 12:06 (2,163 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Mine does have the power wave wash arm. My dishwasher works normally. I use the smart wash, high temp and heated dry. What would be the spray patterns for this setting? |
Post# 995164 , Reply# 24   5/25/2018 at 13:08 (2,163 days old) by Johnb300m (Chicago)   |   | |
Post# 996423 , Reply# 25   6/6/2018 at 21:56 (2,150 days old) by johnb300m (Chicago)   |   | |
Yup, I did it!
I was able to modify the GE clear door I have to fit the current Whirlpool tub platform. So enjoy this quick initial vid of the Rinse Only cycle in the KA. CLICK HERE TO GO TO johnb300m's LINK |
Post# 996435 , Reply# 26   6/7/2018 at 06:55 (2,150 days old) by joeypete (Concord, NH)   |   | |
Post# 996487 , Reply# 27   6/7/2018 at 16:51 (2,150 days old) by appnut (TX)   |   | |
John, thank you. Very interesting and fascinating. Your keeps adding water the first several seconds when it's initially spraying the top rack. I wonder if it does that with each fill segment. Mine doesn't do that except I think it adds between 5 and 10 seconds of more water about 2-3 minutes into the main wash. Mine also alternates between upper and lower 2 or 3 times between the 8-10 minutes of the prewash. |
Post# 996503 , Reply# 28   6/7/2018 at 18:36 (2,150 days old) by johnb300m (Chicago)   |   | |
Bob, that's interesting that yours won't continue to add water till a few minutes in.
So far, mine has always started with the top level first on every fill, and continued to add while running. I wonder if it's to make sure the fill charge is complete. I recon yours is the 'Clean Water Wash' so they might've programmed it differently. The KA will alternate up and down a few times too, if it does a 8-10min pre-wash. Mostly it's been doing a brief 4min prewash. Up, down, drain, purge, then main wash. Or sometimes it'll dump the tab right into the first fill! I'll have to do a full load with the clear door sometime. Busy days lately though. In time. |
Post# 996563 , Reply# 29   6/8/2018 at 10:04 (2,149 days old) by nmassman44 (Brooksville Florida)   |   | |
That video was good to see. I didn't realize that the jets were so tight in diameter coming from the 4 way HydroSweep arm in the base. But it does reaches up to the top of the tank. Very impressive I must say!
I too find it very annoying when someone tries to hijack a thread the way a certain someone likes to...bravo for calling them out on it! |
Post# 996639 , Reply# 30   6/9/2018 at 11:48 (2,148 days old) by johnb300m (Chicago)   |   | |
Thanks Massman44,
The X arm coverage is impressive. Almost representative of the KA hydrosweep arms of yore. I roughed out some jet coverage of the current arm layout. It's very good looking IMO. And the jets have surprisingly good pressure. They indeed pelt the roof of the machine. What I'm very pleased with is the pressure in the upper rack is much stronger than in the old GE, which clearly has been giving very good results lately in the KA. I'm very happy thus far :)
