Thread Number: 75625
/ Tag: Detergents and Additives
Pots n pans cycle |
Post# 994380   5/16/2018 at 15:50 (2,172 days old) by Awooff (Peoria, Illinois)   |   | |
Post# 994394 , Reply# 1   5/16/2018 at 19:08 (2,172 days old) by IowaBear (Cedar Rapids, IA)   |   | |
Most of the cheap timer-controlled dishwashers I used in apartments just added additional pre-washes and rinses cycle prior to the main wash if the "heavy" or "pot and pans" cycle was selected. As you say, I doubt they had that much effect on cleaning unless the machine didn't heat the water and all those water changes brought up the temperature for the main wash.
My current Whirlpool just washes a lot longer on "pots and pans" and heats the main wash even if the option isn't selected. I think it does a better job than the normal cycle (even with the heat option selected.)
It's hard to judge the past dishwashers I used because in those days (prior to 2010) the detergents still used phosphates. Even those BOL dishwashers seemed to do OK for me most of the time. |
Post# 994425 , Reply# 2   5/17/2018 at 06:43 (2,171 days old) by turquoisedude (.)   |   | |
Ironically, the early Pots and Pans cycles on dishwashers (I'm talking late 50s into the mid 60s) were actually shorter than the 'normal' cycle. The idea was that pots and pans would be more or less prewashed by a pot and pan cycle, removed and any remaining heavy soil would be removed by hand washing. This is why these early cycles had a short or no dry cycle. It wasn't until the mid to late 60s that the cycles were extended or added additional washes.
On the current "modern" dishwasher in service in St-Lib (a Maytag WU404), the pots and pans cycle adds one wash to a normal cycle. If the 'sani wash' option is selected, the water is heated through the cycle and it does quite a good job. |
Post# 994625 , Reply# 4   5/19/2018 at 11:47 (2,169 days old) by Awooff (Peoria, Illinois)   |   | |
Well since my kitchwn sink has been plugged up since Saint Patrick's Day (another thread), i cant use my Kenmore powerclean. Been using a maytag in my island and noticed the main wash is much longer for water heating if i use the light wash. Pots and pans on the dial just seems to dump a lot of water and shorter wash time on main wash since its hotter from all the water dumps. A longer main wash seems best here... also been using cascade boil out w phosphates. Tabs in this machine made suds. On a side note, picked up this machine for free as the previous owner thought either his house drain line was plugged or the drain motor on this dishwasher was bad. Haha! I found a grease plug in the drain line is what was plugging it. Evidently someone had just poured grease down his kitchen sink which made its way into the dishwasher drain line.
Post# 994627 , Reply# 5   5/19/2018 at 11:52 (2,169 days old) by vacerator (Macomb, Michigan)   |   | |
on our current dishwasher. The antibacterial cycle has temp. boost, and sani rinse delay. 83 to 90 minutes, depending upon out door temp. and hot water use. It takes less time in warmer weather. House temp. is above 70 F. |
Post# 994878 , Reply# 6   5/22/2018 at 03:57 (2,166 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 995152 , Reply# 7   5/25/2018 at 07:52 (2,163 days old) by dermacie (my forever home (Glenshaw, PA))   |   | |
