Thread Number: 75731
/ Tag: Air Conditioners
Montgomery Ward UFO-5639 A/C unit help. |
Post# 995593   5/29/2018 at 23:14 (2,158 days old) by jholder75 (Knoxville, Tennessee)   |   | |
I just acquired my first vintage window air conditioner.
Montgomery Ward Signature 15,000 btu Model number UFO-5639 It blows nice and cool but the inside fan is horribly noisy on low and boy it is deafening when on high! I have come to conclusion that either there is too much lateral play in the motor shaft or the plastic fan has somehow managed to loosen itself from the metal ring with the allen set screw. I cannot budge the set screw. I do not want to damage this unit as it works very well but I would love for it to be quiet. I would appreciate any guidance and suggestions. Thank you! |
Post# 995851 , Reply# 1   5/31/2018 at 22:44 (2,156 days old) by Supersuds (Knoxville, Tenn.)   |   | |
Did you find it in Knoxville? As far as I know, there never was a Montgomery Ward store here!
This looks like it was made by Frigidaire, and that makes me think the person who could help you would be our member PhilR. He has some Frigidaire window ACs. You might try emailing him in case he doesn't see this thread. |
Post# 995903 , Reply# 2   6/1/2018 at 10:55 (2,155 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It is easy enough to see if the fan hub has come loose from the hub that has the set-screw in it, if so you need a new fan assembly, if not and much more likely is that the fan motor bearings are worn out and you need to replace the fan motor.
These were pretty good A/Cs back in the 70s when they were built, however this thing is among the most inefficient A/C EVER built, these smaller 240 volt units were often pretty bad in terms of operating cost, in addition the compressors were worked so hard because of the undersized condensers these A/Cs used they were not the longest lived machines. [ They did put out really cold air however ] John L. |
Post# 995914 , Reply# 3   6/1/2018 at 14:02 (2,155 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 995961 , Reply# 4   6/2/2018 at 00:02 (2,155 days old) by jholder75 (Knoxville, Tennessee)   |   | |
I don't know how to directly reply to each of you but I wanted to thank you all for your help.
Supersuds: I bought it off a guy in Maryville for $40. It belonged to his mother and I believe he said she lived in Virginia. He said she used it to cool a 15x30 den and always ran it on high. He said it was quite loud but was very cold. They also removed it and cleaned it seasonally.. You could be right about it being made by Frigidaire because the compressor is massive and has that nice deep guttural sound when it kicks on. I did however trace some of the part numbers back to General Electric. The fan motor is definitely GE. Combo52: I do in fact need a new fan assembly as the noise got worse and after an autopsy the back portion where the hub mounts was fractured in several places spreading outward. :( The Torin part number C-299156 / GA800-400-1 could not be found online. But the patent number did find some info about it - Pat# US2652190. I did luck up at a local appliance repair shop and they had an almost exact same fan. Even the same brand! But it has a friction fit clamp to hold the hub onto the shaft and its a little smaller in width but it is working and quiet as can be! I have found a Fasco 1-6006 that might actually be a good replacement and it isn't plastic. I do agree it probably isn't the most energy efficient but it keeps a living room facing south west 68 and the next room about 70-72. I temped the air discharge last at a balmy 42* on low fan.. Goatfarmer: I took the motor with me to appliance shop and had them check it out. They took it apart and checked the windings and oiled it up and said it was in great shape for its age. |
Post# 996042 , Reply# 5   6/2/2018 at 23:53 (2,154 days old) by Supersuds (Knoxville, Tenn.)   |   | |
Post# 996045 , Reply# 6   6/3/2018 at 01:18 (2,154 days old) by Ultramatic (New York City)   |   | |
Post# 996574 , Reply# 7   6/8/2018 at 13:22 (2,148 days old) by jholder75 (Knoxville, Tennessee)   |   | |
Supersuds:
The compressor may have been "compact" for 1971 but this compressor is a beast in my book.. lol.. I will have to snap a pic of it when I pull it out of the window again.. So far I have just been enjoying it.. I do know the compressor from estimating size is about 12" high and probably 8" oval.. Reminds me of a crock pot, but taller.. lol Ultramatic: Thank you :) I have seen you on the vintage appliance and electronics on FB, you are restoring a beautiful Maytag! I hope to see more pics! My dream is to have the Maytag 806 matching pair. :) A guy in Jacksonville FL (Russ R.) has a practically new Hoover twin-tub that I would love to have also. |
Post# 996811 , Reply# 8   6/10/2018 at 23:35 (2,146 days old) by Supersuds (Knoxville, Tenn.)   |   | |
To clarify: What I'm trying to get across is, your unit was made by Frigidaire, not GE, even though it has some GE made parts. A GE unit would have the rotary compressor. Your unit likely has a Tecumseh or Copeland reciprocating compressor.
Here's a link. CLICK HERE TO GO TO Supersuds's LINK |
Post# 997631 , Reply# 10   6/18/2018 at 21:20 (2,138 days old) by jholder75 (Knoxville, Tennessee)   |   | |
These are pics of the compressor. It is still kicking but and keeps up and cycles perfectly. Meanwhile I have a newer (2005) Whirlpool 17,800 btu in the back of the house that struggles to keep up!
