Thread Number: 75804
/ Tag: Vintage Dryers
Frigidaire 1-18 Dryer Felt Seal |
Post# 996361   6/6/2018 at 11:10 (2,150 days old) by joelippard (Hickory)   |   | |
Post# 996365 , Reply# 1   6/6/2018 at 11:39 (2,150 days old) by sfh074 ( )   |   | |
found here ..... CLICK HERE TO GO TO sfh074's LINK on eBay |
Post# 996405 , Reply# 2   6/6/2018 at 16:58 (2,150 days old) by joelippard (Hickory)   |   | |
Post# 996454 , Reply# 3   6/7/2018 at 10:50 (2,149 days old) by TrainGuy (Key West, FL)   |   | |
Joe,
This is the seal that I use as a replacement on every 1-18 dryer I get in. They pop up on eBay all the time. Remember to use high temperature glue and keep the white Teflon side of the seal outward so that the drum rides on it. Use plenty of syl-glide and you'll have a quiet running dryer...better than new. Rich |
Post# 996455 , Reply# 4   6/7/2018 at 10:57 (2,149 days old) by TrainGuy (Key West, FL)   |   | |
Post# 996488 , Reply# 5   6/7/2018 at 17:15 (2,149 days old) by akronman (Akron/Cleveland Ohio)   |   | |
I had ages of trouble and squeaks and mis-aligned assemblies on my 1-18 dryer, every time I did any repairs. Then I taped the door closed, put a blanket on the floor in front of the dryer, and laid it flat on its front for dis-assembly and repairs. In that position, flat on its face, everything went together wonderfully. I completely re-assembled everything while it laid on the floor. Also, any time you're working on a 1-18 dryer, clean up dirt and goop on those 4 rollers, get one drop of turbine oil on each shaft, you'll make them last longer.
Post# 996514 , Reply# 6   6/7/2018 at 20:07 (2,148 days old) by joelippard (Hickory)   |   | |
For the help. I bought what I needed from Rich's link and I had read the tech talk about laying the dryer on it's front. I've worked on them sitting up before and it's difficult. I also learned from the tech talk about loosening the one side of the bottom roller to make getting the bulkhead back in easier. Thanks again! |
