Thread Number: 76031
Kennore top of the line washer |
Post# 998854 , Reply# 1   6/30/2018 at 00:56 (2,127 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Eventually the balance ring is broken and the "oil" you see is actually the balance ring fluid. Open the top and check the inner part of the cabinet if there is any spray marks. This is rare but not impossible. |
Post# 998872 , Reply# 2   6/30/2018 at 08:10 (2,127 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
The jumping spin basket probably has nothing to do with the oil on the base. This era had some instances where the lock nut on the drive would work it's way loose and allow the basket to "flop" around, eventually not spinning properly. It's best to replace the basket drive block and lock ring, and possibly the spin tube as the loose hub could wear down the tang that it was supposed to be locked onto.
Post# 998877 , Reply# 4   6/30/2018 at 08:30 (2,127 days old) by Tomdawg (Des moines)   |   | |
Ok, found by looking the suspension plate was turned around- so I fixed the jumping/ balancing issue. The bleach and fabric softener doesn’t fill with water on the triple dispense. Any ideas where to look in there? |
