Thread Number: 76166
/ Tag: Air Conditioners
Dehumidifier fan won't shut off |
Post# 1000060 , Reply# 1   7/11/2018 at 22:56 (2,115 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Does lowering the humidistat have any effect? |
Post# 1000062 , Reply# 2   7/11/2018 at 23:05 (2,115 days old) by petek (Ontari ari ari O )   |   | |
I'm guessing that's not normal for your machine. Mine only runs the fan when the compressor is running as well.. However new machines like the one Delonghi I bought for moms house a few years back,, the fan ran continuously by design.. I wasn't impressed. And on my mini split a/c,, same thing, the fan runs continuously as well.
Post# 1000145 , Reply# 4   7/12/2018 at 22:25 (2,114 days old) by IowaBear (Cedar Rapids, IA)   |   | |
I just replaced mine this spring with a recent model Frigidaire I got almost new off CL. The fans runs all the time.
But once in while (every hour or so) it does shut off, like for a minute or two, and then turns back on. No idea why it does this. It's quieter overall than the 15 year-old one it replaced.
9 years isn't a bad lifespan for one, I read a Consumer Reports article that said many of the newer ones aren't lasting more than 3 or 4 years.
Post# 1000153 , Reply# 5   7/13/2018 at 02:11 (2,114 days old) by petek (Ontari ari ari O )   |   | |
Post# 1000156 , Reply# 6   7/13/2018 at 03:33 (2,114 days old) by speedqueen (Metro-Detroit)   |   | |
If it is electronically controlled, perhaps there is a relay on the board stuck in circuit closed position causing the fan to never shut off. Stuck relays often cause death of uninterruptible power supplies. You could see if a new board is available for it. If you know someone handy with electronics, they might be able to fix the board. Ham radio operator, perhaps. |
Post# 1000203 , Reply# 8   7/13/2018 at 17:12 (2,113 days old) by IowaBear (Cedar Rapids, IA)   |   | |
I think the humidity sensor was bad on my LG-made Kenmore. It would run for a little while if I set it on 40% setting but wouldn't keep the basement anywhere near where it should be.
The part was available and cheap, but at 15 years-old I just figured it had done its time.
Who knows, maybe a mistake, with a new sensor it might have outlasted the "new" one. I actually bought it used off CL, but it was only a year old, like new, guy had sold his house, moving out of state.
CLICK HERE TO GO TO IowaBear's LINK |
