Thread Number: 76323
Searching... |
Post# 1001540 , Reply# 1   7/26/2018 at 19:43 (2,100 days old) by richimaor (Baja California, Mexico)   |   | |
Although I did investigate various times and found nothing... |
Post# 1001541 , Reply# 2   7/26/2018 at 19:58 (2,100 days old) by Yogitunes (New Jersey)   |   | |
there wasn't a lot available in Ebony at the time.....mainly it was a Limited Set or a Lady K....basically TOL for that color....everything else was either white or almond...
but these series would have been discontinued by 2000..... |
Post# 1001542 , Reply# 3   7/26/2018 at 20:00 (2,100 days old) by Yogitunes (New Jersey)   |   | |
the only other pair that I know of that was under the Kenmore name, supplied by Frigidaire....
Post# 1001545 , Reply# 5   7/26/2018 at 20:07 (2,100 days old) by Yogitunes (New Jersey)   |   | |
Post# 1001575 , Reply# 7   7/27/2018 at 06:42 (2,100 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This is certainly the only black FL pair that Sears sold although they did sell the larger German built WPs in dark gray and dark blue shades.
These FD built machines were not small machines, but also not quite as large as the WPs. The FD washer was a decent performer and fairly durable [ the electronic control was sometimes a problem ], The dryer [ well it was an old WH design ] was just ok, it was a little small, ran hot in the rear of the drum and had about about 1/2 the longevity of a WP built dryer.
Post# 1001666 , Reply# 10   7/27/2018 at 21:39 (2,099 days old) by Yogitunes (New Jersey)   |   | |
my only issue is this machine is a Tier 3 for water usage, which translates into using less water....
the water level is not adjustable, so we just had to improvise.... I have the gas dryer, with the burner underneath, the back wall doesn't get as hot as the electric version..... basically you run Normal wash, warm/hot wash, cold rinse, extended spin...press start and it repeats over and over...spins very well..... CLICK HERE TO GO TO Yogitunes's LINK |
Post# 1001675 , Reply# 11   7/27/2018 at 23:19 (2,099 days old) by IowaBear (Cedar Rapids, IA)   |   | |
Post# 1001732 , Reply# 12   7/28/2018 at 11:00 (2,099 days old) by richimaor (Baja California, Mexico)   |   | |
That is totally awesome, very clever way to increase water level. I did increase water level from 3” to 5” around a year ago but went back to 3” since the added weight finished up messing the old shocks. |
