Thread Number: 76400
lip seal |
Post# 1002451   8/3/2018 at 19:03 (2,092 days old) by Petemo (Sheridan, Wyo)   |   | |
Help! I have a A506 Maytag washer. I replaced the lip seal, reassembled and now the washer is off balanced and making weird noises. I must have did something wrong! Any ideas? |
Post# 1002464 , Reply# 1   8/3/2018 at 21:34 (2,091 days old) by potatochips ( )   |   | |
By lip seal you mean tub seal?
The tub may not be centered properly and is scraping up against the outer tub. Is it a scraping sound? |
Post# 1002533 , Reply# 5   8/4/2018 at 14:11 (2,091 days old) by Petemo (Sheridan, Wyo)   |   | |
Yes, goodshepherd, you're right on. It was the lug stop setting. I'm sure the damper pads are worn but I didn't see them. I wanted to add oil to the helical transmission but didn't see where to add oil. I did replace 2 bearings and lubed everything I could. Thanks again. |
Post# 1002552 , Reply# 7   8/4/2018 at 15:33 (2,091 days old) by RP2813 (Sannazay)   |   | |
