Thread Number: 822
Kenmore Model 82980120 Back Panel Removal |
Post# 51575 , Reply# 2   12/22/2004 at 08:50 (7,065 days old) by CleanteamofNY ((Monroe, New York)   |   | |
Since you have a Direct Drive washer, check the screen at the valve, you must pull the machine away from the wall and remove the hose from the machine and not the faucet. If you see a build up on the screen, clean with a toothbrush only! DO NOT REMOVE SCREEN OR DAMAGE TO THE VALVE WILL OCCUR! Turn on water though the hose to make sure you have enough water pressure going through, if that checks out OK and the valves screens are clear, then the valve may need to be replaced. P.S., check and see if screens are placed on the faucet end too!!! Larry |
Post# 51584 , Reply# 3   12/22/2004 at 11:41 (7,065 days old) by Goatfarmer (South Bend, home of Champions)   |   | |
I agree on the plugged filters in the hose. You can't remove the back on a DD,you remove the whole cabinet.UNPLUG the machine,take out 2 screws that hold the console in place.Flip the console back,and you will see 2 large clips that hold the cabinet to the rest of the washer.Remove the 2 clips,with a large screwdriver,unplug the connector for the lid switch,and lift the cabinet off. kennyGF |
Post# 51596 , Reply# 4   12/22/2004 at 13:14 (7,064 days old) by veg-o-matic (Baltimore, Hon!)   |   | |
I don't know if this has anything to do with the issue at hand--but that's not going to prevent me from sharing! We had a '69 Kenmore. Forget the model, but I still have the instruction manual. Anyhoo, it was ALWAYS slow in filling, even from day one. We had good water pressure and all screens were clean. But still, it looked like the water was just sort of *dripping* into the tub. This machine was later replaced by another Kenmore--'82 maybe--and it filled significantly faster. |
