Thread Number: 8400
More Maytag mayhem... with pics... |
Post# 159236   10/7/2006 at 09:45 (6,422 days old) by labaglia ()   |   | |
First I would like to thank everyone who in the past helped me with my old Maytags Here is a picture of what you've helped keeping around |
Post# 159238 , Reply# 1   10/7/2006 at 09:48 (6,422 days old) by appnut (TX)   |   | |
Post# 159240 , Reply# 3   10/7/2006 at 09:51 (6,422 days old) by labaglia ()   |   | |
This is a view of the side with more brown spots |
Post# 159241 , Reply# 4   10/7/2006 at 09:52 (6,422 days old) by labaglia ()   |   | |
this is an inside view but can't se were leak might be.... |
Post# 159293 , Reply# 6   10/7/2006 at 14:35 (6,422 days old) by pdub (Portland, Oregon)   |   | |
Transmission Rebuild. There is an o-ring at the bottom of the inside of the transmission shaft that has probably worn out. When it no longer provides a good seal it allows oil to leak past and when your machine spins it flings it around under the bottom of the cabinet. Very normal for the age of your machine. I bet if you tip your machine up and look at the bottom there will be an oil coating underneath. It's not an easy repair for the novice but can be done and the parts are still available. Christfr in St. Louis just rebuilt his, but then again he is the macho ambitious type! I would recommend spending the money and the machine will probably last another 20-25 years. Good Luck. Patrick |
Post# 159460 , Reply# 8   10/9/2006 at 06:43 (6,420 days old) by christfr (st louis mo)   |   | |
hey there its really not a hard job just takes time. i was lucky i had someone help me through the repair and i did just fine..first find a repair master book and read through it.. then i got the parts i needed at repair clinic . com.. youll need one bott of trans oil one trans gasket and one o ring seal and a set of belts.. thats usually it.. the oil is leaking from an o ring seal in the trans its about the size of a dime and the oil is going down the agi shaft and when the machine spins it slings the oil out onto the floor.. the underside of the machine where the belts are is prob coated with oil.. its a messy job but not to hard.. the whole machine has to come apart and the trans has to be cracked in half to do this job..but once the job is done and you replace the belts and clean the underside that machine should run another 40 years..
Post# 159468 , Reply# 9   10/9/2006 at 07:59 (6,420 days old) by labaglia ()   |   | |
I found this: CLICK HERE TO GO TO labaglia's LINK |
Post# 159469 , Reply# 10   10/9/2006 at 08:18 (6,420 days old) by christfr (st louis mo)   |   | |
Post# 159536 , Reply# 11   10/9/2006 at 19:22 (6,420 days old) by labaglia ()   |   | |
It would be highly appreciated thanks |
Post# 159596 , Reply# 12   10/10/2006 at 06:12 (6,419 days old) by christfr (st louis mo)   |   | |
