Thread Number: 21032
i got my filter flow today i am so excited!! |
Post# 332813 , Reply# 2   2/28/2009 at 21:39 (5,550 days old) by ttuee2006 ()   |   | |
Check the belt tension. The motor is on 3 bolts and can be tightened up. |
Post# 332819 , Reply# 3   2/28/2009 at 21:54 (5,549 days old) by toploader1984 ()   |   | |
new filter flo |
Post# 332820 , Reply# 4   2/28/2009 at 21:56 (5,549 days old) by toploader1984 ()   |   | |
pics |
Post# 332821 , Reply# 5   2/28/2009 at 21:57 (5,549 days old) by toploader1984 ()   |   | |
splashy wash |
Post# 332822 , Reply# 6   2/28/2009 at 21:58 (5,549 days old) by toploader1984 ()   |   | |
they look awesome! |
Post# 332823 , Reply# 7   2/28/2009 at 21:59 (5,549 days old) by toploader1984 ()   |   | |
spin cycle |
Post# 332824 , Reply# 8   2/28/2009 at 22:01 (5,549 days old) by toploader1984 ()   |   | |
i LOVE this rampie agitator! |
Post# 332852 , Reply# 9   12/31/2069 at 18:00 (19,854 days old) by toploader1984 ()   |   | |
i checked the tention on the belt, there is a tad bit of slack, not much tho, i can move the side of the belt, should it be tighter? |
Post# 332922 , Reply# 11   3/1/2009 at 10:10 (5,549 days old) by toploader1984 ()   |   | |
cool, thanks for the advice eric! i am going to try it out and let u know how it goes. |
Post# 333094 , Reply# 15   3/1/2009 at 22:58 (5,548 days old) by ttuee2006 ()   |   | |
Hmm.....the clutch assembly is a dry-type, so if you're seeing sprayed oil, look for a leaking transmission. Does the belt have grease on it too? If so it's probably slipping pretty bad. |
Post# 333188 , Reply# 17   3/2/2009 at 12:59 (5,548 days old) by iheartmaytag (Wichita, Kansas)   |   | |
reminds me of a game we played in the boy's room as kids. Sometimes lint and hair can partially clog the passage for the recirculation water. It's just a matter of cleaning it out, you can get to it while you are under tightening the belt. The old GE/FF my mother had had a clear neck on the connection so you could see if it were blocked. |
