Thread Number: 33776
How to place a washer into storage? |
Post# 507584   3/28/2011 at 11:58 (4,640 days old) by danmantn (Tennessee)   |   | |
My beloved 2003 TOL Whirlpool Gold top load washer is going into storage for my sister to use when they build their house...which will be 1 to 2 years. Any pointers other than to do a "clean cycle" and make sure that it is dry? Gotta make way for my new Speed Queen set that is coming next week for the house.
Post# 507593 , Reply# 2   3/28/2011 at 12:26 (4,640 days old) by danmantn (Tennessee)   |   | |
Post# 507611 , Reply# 3   3/28/2011 at 13:02 (4,640 days old) by kenmoreguy64 ![]() |
Dan -
Is the washer going to be exposed to freezing temps? If so, be sure the mixing valve is drained, and water is out of the pump. If that is not a concern, then you're probably fine just packing it away. I think the suggestion of lowering the drain hose is good though - it will allow most of the excess water to drain out and not mildew later, etc. So what are you getting new? Gordon |
Post# 507612 , Reply# 4   3/28/2011 at 13:06 (4,640 days old) by danmantn (Tennessee)   |   | |
Post# 507613 , Reply# 5   3/28/2011 at 13:06 (4,640 days old) by danmantn (Tennessee)   |   | |
Post# 507621 , Reply# 6   3/28/2011 at 13:34 (4,640 days old) by kenmoreguy64 ![]() |
Post# 507622 , Reply# 7   3/28/2011 at 13:44 (4,640 days old) by danmantn (Tennessee)   |   | |
Post# 507667 , Reply# 8   3/28/2011 at 15:59 (4,640 days old) by mrb627 (Buford, GA)   |   | |
Post# 507682 , Reply# 9   3/28/2011 at 16:27 (4,640 days old) by CleanteamofNY ![]() |
Do not drain washer completely before storing because the seals in the pump will dry rot. It is recommended to use RV Antifreeze, use more or less 1-2 quarts and run the last two minuets of a spin cycle to mix water and RV antifreeze to protect the pump from drying out and seizing.
Please read your manual for further instructions! CLICK HERE TO GO TO CleanteamofNY's LINK |
Post# 507731 , Reply# 10   3/28/2011 at 18:57 (4,640 days old) by yogitunes ![]() |
Post# 507742 , Reply# 11   3/28/2011 at 19:26 (4,640 days old) by combo52 ![]() |
