Thread Number: 34750
Memorial Day Weekend Treat - Easy Spin-Drier Washer In NJ! |
Post# 520968   5/28/2011 at 07:18 (4,716 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 520970 , Reply# 1   5/28/2011 at 07:20 (4,716 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 521068 , Reply# 2   5/28/2011 at 14:55 (4,716 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 521071 , Reply# 3   5/28/2011 at 15:04 (4,716 days old) by akronman (Akron/Cleveland Ohio)   |   | |
This looks like one of the low end models, you just use a hose from your faucet for wash fill and for rinsing in the spin tub. For saving suds from the spinner when sudsy clothes get their first spin, you'd hold the drain hose back into the wash side. Upper models were EASY-er, but the results are the same. Fun machines, clean clothes.
Post# 521077 , Reply# 4   5/28/2011 at 15:20 (4,716 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 521129 , Reply# 5   5/28/2011 at 19:03 (4,716 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Even if fully operational now, couple weeks' use and it may not be. I'd bargain down from that standpoint. Same would be true even if it was NIB, those materials don't just sit there for 60 years and not deteriorate. Externally though, pristine, couldn't be better. The porcelain tended to hold up but the painted cabinet didn't.
Not sure where 'in the line' grandma's was but it had faucets (no valves though, that was up to user) however the suds saver required you to move the drain hose. |
