Thread Number: 35770
BOSCH Dishwasher
Cool Washer Stuff on Amazon:
scroll >>> for more items
Post# 533554   7/28/2011 at 22:14 (4,517 days old) by timborow (Georgia)
Hello guys. I have a Bosch SHU53 that isn't working properly. It will not cycle off and the display window says 2H. I had a repairman out today, and he showed me to depress the scrub and delicate buttons together to reset it. When he did it, the dishwasher worked fine. I paid him his service charge and thought everything was fine, but it is doing the same 2H thing again. The cycle runs forever. I have tried resetting it. It goes to CL. I turn it off and on again, and it still doesn't cycle off. Any suggestions before I call him back out again for another $45 fee? BTW the Rinse/Hold feature works fine, but all the other cycles read 2H. Sure hope it's a simple fix. Thanks in advance.
Tim
Post# 533601 , Reply# 1   7/29/2011 at 09:22 (4,517 days old) by joe_in_philly (Philadelphia, PA, USA)
joe_in_philly's profile picture
Is it heating the water? Does it dispense the detergent? After it has run for 30 minutes or so, it should be at the part of the cycle where it is heating the wash water. If you open the dishwasher, it it hotter than the hot tap water?
Since Bosch dishwashers heat the water to a set temp, if the heater goes then the cycles can take a very long time.
CLICK HERE TO GO TO joe_in_philly's LINK
Post# 533602 , Reply# 2   7/29/2011 at 09:24 (4,517 days old) by joe_in_philly (Philadelphia, PA, USA)
Here is another link that may be helpful.
