Thread Number: 37244
Need help identifying Kenmore double oven |
Post# 553879 , Reply# 1   11/3/2011 at 15:24 (4,579 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 553943 , Reply# 3   11/3/2011 at 18:12 (4,579 days old) by DADoES (TX, U.S. of A.)   |   | |
The diagrams at SearsPartsDirect.com aren't good quality but the small oven door gasket is part number 1303777 if I'm interpreting correctly. Says NLA. Both thermostats are also listed NLA. Part numbers 1307902 and 1307472 (can't determine which is large or small oven). I'd figure there's a generic replacement that would work. Interesting what pieces are listed as available.&bnsp; Of five choices for the rangetop (different colors, presumably), one is listed as "contact customer service for availability" and one is stated as "in stock." |
Post# 554016 , Reply# 6   11/4/2011 at 07:42 (4,578 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It does sound like the thermostat is at fault, a generic thermostat could probably be installed by a competent repair person. The range would date from the late 1960s- about 1972 after 1972 convenience outlets were removed from all gas and electric ranges under a new UL rule that was very much agreed to by the range manufactories, it saved them money. |
Post# 554277 , Reply# 8   11/5/2011 at 12:08 (4,577 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 554294 , Reply# 9   11/5/2011 at 12:50 (4,577 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 554397 , Reply# 10   11/5/2011 at 22:17 (4,577 days old) by appnut (TX)   |   | |
