Thread Number: 49842
Center dial MT A806 in Mpls |
Post# 720003   12/8/2013 at 19:44 (3,399 days old) by whirlykenmore78 ![]() |
Post# 720010 , Reply# 1   12/8/2013 at 19:55 (3,399 days old) by rp2813 ![]() |
Post# 720213 , Reply# 2   12/9/2013 at 16:31 (3,398 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 720226 , Reply# 3   12/9/2013 at 17:44 (3,398 days old) by Kenmore71 ![]() |
![]() Meh. I've never run across a poly pump OR a nylon fill valve (that was disconnected) that was cracked because of freezing. And, for that matter, ice actually contracts every so slightly as it gets colder. The expansion properties of water freezing into ice does its worst damage right at 32 degrees F.
The only pumps that could really be damaged by freezing are those made out of aluminum or pot metal. |
Post# 720241 , Reply# 4   12/9/2013 at 19:34 (3,398 days old) by swestoyz ![]() |
I'm sure Mark remembers a Waterloo visit, where we found an early 90's Maytag behind Menards, in the middle of winter. After letting it thaw, the pump and valve were fine.
I have seen water valves split, but never a Maytag poly pump. This would be a great washer for someone in the Twin Cities area! Ben |
Post# 720276 , Reply# 5   12/10/2013 at 00:43 (3,397 days old) by washer111 ()   |   | |
Where is Robert? Perhaps there is some room in his basement for this! |
Post# 720376 , Reply# 6   12/10/2013 at 13:55 (3,397 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 720402 , Reply# 7   12/10/2013 at 16:06 (3,397 days old) by goatfarmer ![]() |
Post# 720403 , Reply# 8   12/10/2013 at 16:09 (3,397 days old) by Unimatic1140 ![]() |
Post# 720404 , Reply# 9   12/10/2013 at 16:17 (3,397 days old) by Kenmore71 ![]() |
