Thread Number: 56397
Good time to buy a Speed Queen |
Post# 787096 , Reply# 1   10/3/2014 at 17:50 (3,492 days old) by JeffG ()   |   | |
That 542 sounds tempting. Are these the last of the mechanical timer SQs? |
Post# 787099 , Reply# 2   10/3/2014 at 18:14 (3,492 days old) by hvtech42 (New England)   |   | |
I doubt these are the last mechanical washers, looking at their roadmap it appears they will introduce electronic controls in 2015, but only on higher end models. It looks as if they will keep a mechanical control model available until at least 2018. |
Post# 787128 , Reply# 5   10/3/2014 at 20:37 (3,492 days old) by mtn1584 (USA)   |   | |
Where did you get this info from Ben? Mike |
Post# 787129 , Reply# 6   10/3/2014 at 20:41 (3,492 days old) by mtn1584 (USA)   |   | |
WOW!!! CLICK HERE TO GO TO mtn1584's LINK |
Post# 788741 , Reply# 9   10/13/2014 at 01:40 (3,483 days old) by JeffG ()   |   | |
"Also, is it common for the dealership to adjust the water level too maximum fill if the customer asks for it?" No harm in asking, and if they say no it's an extremely easy DIY adjustment. |
Post# 788821 , Reply# 13   10/13/2014 at 13:11 (3,483 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Wasn't there a way to rewire the rinse fill ports on the timer so when ever the rinse cam activates the cold valve the hot one is energized as well giveing you warm rinses for any rinse cycle independent if cycle and temperature selected? |
