Thread Number: 56891
/ Tag: Classified Ad Finds
Frigidaire Drop-In Stove, Hood and DW (?brand) -$100 (Merriam, Ks) |
Post# 791901   11/3/2014 at 21:09 (3,471 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 791907 , Reply# 1   11/3/2014 at 21:25 (3,471 days old) by bigalsf (Salt Lake City)   |   | |
Either a 19 or 20 series. Can't tell from picture. |
Post# 791915 , Reply# 2   11/3/2014 at 22:08 (3,471 days old) by PhilR (Quebec Canada)   |   | |
Post# 791917 , Reply# 3   11/3/2014 at 22:21 (3,471 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
I can understand the burst delivered in a short interval of 220v, but the Heat Minder? Have you any noticeable occasions when this feature was critical to your cooking? I just don't understand why the turning off and on would be any different than a thermostat that regulates the temperature. Or is it designed to turn off the oven when temperatures are too hot, which occur more often at ? settings? Just trying to piece together the value of a Heat Minder.
Post# 791920 , Reply# 4   11/3/2014 at 22:45 (3,470 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 791921 , Reply# 5   11/3/2014 at 23:00 (3,470 days old) by PhilR (Quebec Canada)   |   | |
Post# 791922 , Reply# 6   11/3/2014 at 23:01 (3,470 days old) by PhilR (Quebec Canada)   |   | |
Honestly, many don't make the difference between a sensor-controlled burner and a regular infinite switch controlled burner! They might start on a high temperature to turn it down to the correct temperature later while it would have done it by itself if set to the correct temperature in the first place! There's also a note in the instructions below that suggest always turning the control to off when the utensil is removed from the burner. That's something that many users don't get and they're surprised to see the burner getting really hot on a low setting while there's no utensil on it!
A sensor-controlled burner will start on full heat and then cycle to maintain the correct temperature like an oven does. A burner controlled by an infinite switch will take longer to heat up if you leave it on low and don't adjust the temperature.
Here's a copy of the Heat Minder guide for my 1966 RJ-39K range and the various suggested temperatures... |
