Thread Number: 57356
/ Tag: Classified Ad Finds
Pink CI Dishmobile Like New $200 (Oakland) |
Post# 796908   12/2/2014 at 01:22 (3,442 days old) by rp2813 (Sannazay)   |   | |
On SF Bay Area CL.
Pricey, but it appears to have had little or no use.
CLICK HERE TO GO TO rp2813's LINK on San Francisco Craigslist |
Post# 796945 , Reply# 1   12/2/2014 at 07:49 (3,442 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
it's funny -I posted this first, then someone else , and now a third appearance.
With so much exposure,too bad the seller doesn't see the "pricey" comments we've all posted.
Post# 796988 , Reply# 2   12/2/2014 at 13:01 (3,442 days old) by rp2813 (Sannazay)   |   | |
LOL Phil! I missed your original post and was wondering why this one had flown under your precision radar!
It's too expensive unless you're a collector who needs to have one in every color. From what I've been told and read here, the spin tube system leaves much to be desired as far as cleaning dishes is concerned. |
Post# 797042 , Reply# 3   12/2/2014 at 20:56 (3,441 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 797246 , Reply# 4   12/3/2014 at 22:05 (3,440 days old) by roto204 (Tucson, AZ)   |   | |
I had a turquoise Custom Imperial, and it washed beautifully--pots, pans, and all. It had a covered detergent dispenser, and two washes. The key to success was HOT water, and following the loading guide, conveniently glazed into the door.
Two down-sides: Plates larger than nine inches clip the bottom of the top rack, and that top rack--with everything needing to be canted toward the spin-tube--filled up far more quickly than the bottom rack did. |
Post# 797249 , Reply# 5   12/3/2014 at 22:25 (3,440 days old) by rp2813 (Sannazay)   |   | |
Post# 797254 , Reply# 6   12/3/2014 at 22:39 (3,440 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
never mind - this is for washers, not dishwashers! jeez, it's later….than I think here in life. :-)
CLICK HERE TO GO TO ovrphil's LINK |
Post# 797318 , Reply# 7   12/4/2014 at 08:16 (3,440 days old) by turquoisedude (.)   |   | |
Post# 797327 , Reply# 8   12/4/2014 at 09:56 (3,440 days old) by roto204 (Tucson, AZ)   |   | |
It's THE wash arm in the machine; everything in the bottom rack must also be hit by the whirling tube, or it doesn't get clean. You position fry pans and pots sideways to accomplish this, and astonishingly, it does work.
There is a constant rinse on the top of the tank (or was on mine), which helped. The only thing in the bottom is the floating spring-loaded filter module over the sump intake. (A cute self-cleaning filter contraption, which works well if you don't overload it with food chunks.) Frigidaires move TONS of water with a monster impeller in the pump--the tube to carry water to the spin-tube is huge as well. When they drain, they can fill the sink or disposer very quickly. They're a lot of fun, and I love the way they sound like a steady rain-shower when they run. |
Post# 797358 , Reply# 9   12/4/2014 at 13:36 (3,440 days old) by PhilR (Quebec Canada)   |   | |
They're fun machines indeed! I still have the undercounter version that Robert gave me in my kitchen! I love it!
Post# 797652 , Reply# 11   12/6/2014 at 06:33 (3,438 days old) by turquoisedude (.)   |   | |
Post# 797692 , Reply# 12   12/6/2014 at 11:50 (3,438 days old) by Carolinacat (north carolina)   |   | |
Replied back to you. |
Post# 797760 , Reply# 13   12/6/2014 at 18:46 (3,437 days old) by Carolinacat (north carolina)   |   | |
Update. Jackie now has a drop off alot closer to me which makes this very possible. Still need to contact the seller again will keep everone informed. |
Post# 797766 , Reply# 14   12/6/2014 at 18:59 (3,437 days old) by turquoisedude (.)   |   | |
