Thread Number: 57510
/ Tag: Classified Ad Finds
Today's Ranges at the Recycler... |
Post# 798879   12/13/2014 at 14:24 (3,431 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 798881 , Reply# 1   12/13/2014 at 14:26 (3,431 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 798883 , Reply# 2   12/13/2014 at 14:28 (3,431 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 798884 , Reply# 3   12/13/2014 at 14:30 (3,431 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 798886 , Reply# 4   12/13/2014 at 14:32 (3,431 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 798887 , Reply# 5   12/13/2014 at 14:34 (3,431 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 798889 , Reply# 6   12/13/2014 at 14:37 (3,431 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 798891 , Reply# 7   12/13/2014 at 14:50 (3,431 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
....Is a screaming deal for someone who can handle Coppertone. I find it too difficult to keep sparkling clean; it shows fingermarks worse than stainless.
The companion oven seems to have the lift-off liners that go in the main oven for self-cleaning, greatly easing the job of cleaning the companion oven. The price is very right, too. |
Post# 798892 , Reply# 8   12/13/2014 at 14:55 (3,431 days old) by pulltostart (Mobile, AL)   |   | |
Post# 798924 , Reply# 9   12/13/2014 at 18:30 (3,431 days old) by lamont ()   |   | |
That roper is not worth what they are asking. 150 max. No griddle, single oven, not really desireable as a collector. |
Post# 798926 , Reply# 10   12/13/2014 at 18:39 (3,431 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 798927 , Reply# 11   12/13/2014 at 18:57 (3,431 days old) by appnut (TX)   |   | |
Post# 798931 , Reply# 12   12/13/2014 at 19:24 (3,431 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Post# 798957 , Reply# 13   12/13/2014 at 22:01 (3,431 days old) by Tomturbomatic (Beltsville, MD)   |   | |
That is a removable lower panel in the companion oven. The secret to keeping coppertone sparkling is that after washing and rinsing it and wiping it dry is to give it a final wipe with some vinegar to kill all tendency of streaks. |
Post# 798975 , Reply# 14   12/14/2014 at 03:30 (3,430 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
I know about the vinegar trick and it does work.
Until the next time someone touches the appliance. I found Coppertone to have the same problem showing fingermarks as stainless, only maybe even more so. When I left home, I didn't waste much time trying to acquire some of the glamorous Coppertone appliances I had envied other people - my mom was a firm believer in White, so the grass was copperier on the other side of the fence, right? Well, I found a Coppertone range and fridge and prepared to settle into glamorous bliss.... NOT. It was a struggle from first to last to keep the damn things looking sparkling. I rid myself of them at the first opportunity, and have tried to stick to White ever since. |
Post# 799018 , Reply# 15   12/14/2014 at 09:28 (3,430 days old) by turquoisedude (.)   |   | |
Post# 799022 , Reply# 16   12/14/2014 at 09:52 (3,430 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 799133 , Reply# 17   12/14/2014 at 22:25 (3,430 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 799140 , Reply# 18   12/14/2014 at 23:16 (3,430 days old) by PhilR (Quebec Canada)   |   | |
That's a very nice range John!
I'm curious about the clock, it looks like a very early model from the first series of Compact 30 ranges (1962).
The range itself should be a 1975 RBE 533, a 1973-74 RBE3-533W, or a 1971-72 RBE-533P (the 1969-70 version had a different "lock" knob for the oven door, see the last pictures for the early type).
The 1975 RBE-533 (in which the "E" stands for "Electri-Clean") has the exact same model number as the 1962-1963 RBE-533 (in which the "E" was designating the production years), I'm wondering if the timer was replaced at some point and the replacement timer was ordered for a 1962 range by error!
The two first pictures show the 1975-style RBE-533 clock, the third one shows the clock on my RBE-539N (mine was made in 1969 but it's a 1968 model and it's almost the same as the RBE-533P but with the added Speed Heat and Heat Minder burners).
1968 was the first year for a self-cleaning Compact 30 range and there was just one model available which featured the Speed Heat and Heat Minder burners. In 1969, another self-cleaning model without the SH and HM burners was introduced. Both ranges were produced with minimal changes for a few years. |
Post# 799141 , Reply# 19   12/14/2014 at 23:30 (3,430 days old) by PhilR (Quebec Canada)   |   | |
Here's a 1962 clock to compare.
Post# 799153 , Reply# 20   12/15/2014 at 01:35 (3,429 days old) by hippiedoll ( arizona )   |   | |
PhilR:
OOOOWWW!! i like the look of the clock numbers set up on the 1962 clock. the styling of the layout of the numbers looks cool!! thank you for sharing the pictures... :o) combo52: CONGRATULATIONS!!!!!!!! on the "Poppy Frigidaire Drop-In Range". it looks like it is in GREAT condition. i don't see any burned oil or grease around or under the chrome burner rings. it looks so clean, i wonder if it was ever used?? don't forget to share pictures when you get a chance to take them!!! ;o) |
Post# 799188 , Reply# 21   12/15/2014 at 10:07 (3,429 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
Post# 799190 , Reply# 22   12/15/2014 at 10:10 (3,429 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
