Thread Number: 57727
/ Tag: Classified Ad Finds
Gas 1950's Westinghouse Dryer - $40 (Bath) |
Post# 801515   12/29/2014 at 22:56 (3,415 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 801542 , Reply# 1   12/30/2014 at 06:15 (3,414 days old) by Tomturbomatic (Beltsville, MD)   |   | |
WH did not make gas dryers until the straight front design, but many of their electric dryers could be used on 120 volt service. Maybe this one just has a 120 volt cord on it and the seller thought that it was a gas dryer. |
Post# 801546 , Reply# 2   12/30/2014 at 06:54 (3,414 days old) by alr2903 (TN)   |   | |
One slow @ss gas dryer! |
Post# 801548 , Reply# 3   12/30/2014 at 08:35 (3,414 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Probably about as fast as "Warm" setting on the Wards gas dryer by Norge that used a 1000 watt electric element to provide heat on the "Warm" setting. Of course, with the Norge's airflow, it might have been faster. |
Post# 801550 , Reply# 4   12/30/2014 at 08:56 (3,414 days old) by appnut (TX)   |   | |
Post# 801562 , Reply# 5   12/30/2014 at 11:58 (3,414 days old) by arris (Rochester New York)   |   | |
Post# 801579 , Reply# 6   12/30/2014 at 17:12 (3,414 days old) by ken (NYS)   |   | |
So were WH dryers of this era manufactured to switch between using 120/220 volt by changing the wiring connections inside? If the dryer is currently set up for 120 usage is a simple connection change internally all that's necessary to use it on 220? Or did they manufacture two different lines of dryers: 120 & 220 volt?
