Thread Number: 58254
1970 Kenmore Washer |
Post# 807670   2/4/2015 at 20:05 (3,368 days old) by ind75k99 ()   |   | |
My Kenmore washer model #7014502 began to squeal in spin and chewed up the belt. Motor is new. Any idea of repair needed? Thank You |
Post# 807688 , Reply# 1   2/4/2015 at 22:39 (3,368 days old) by rp2813 (Sannazay)   |   | |
Post# 807720 , Reply# 2   2/5/2015 at 07:00 (3,368 days old) by turquoisedude (.)   |   | |
Post# 808222 , Reply# 3   2/8/2015 at 13:40 (3,364 days old) by ind75k99 ()   |   | |
The pump is free and alll else turns well. What next? Thanks to all. |
Post# 808224 , Reply# 4   2/8/2015 at 13:45 (3,364 days old) by rp2813 (Sannazay)   |   | |
Post# 809466 , Reply# 5   2/15/2015 at 18:07 (3,357 days old) by ladyk (Tacoma)   |   | |
Sounds like either bad center post bearings or a lack of lubrication if they are still good. Basket drive clutches may be worn down so that you've got metal on metal. Hope that helps a little. |
Post# 809513 , Reply# 6   2/15/2015 at 21:43 (3,357 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
There is not much that will chew up a belt in a Belt Drive WP-KM washer other than a sized water pump, how fast did this belt get chewed up, what is getting hot, Motor pulley, clutch pulley ?, if the motor pulley has any rust on it it will chew up a belt pretty fast, you really have to look the machine over and it should be pretty easy to figure out what is causing the belt wear and noise. |
Post# 810847 , Reply# 8   2/23/2015 at 22:07 (3,349 days old) by ind75k99 ()   |   | |
If all looks good might this be the transmission? I'm in need of this washer. Kent |
Post# 810865 , Reply# 9   2/24/2015 at 01:31 (3,349 days old) by ladyk (Tacoma)   |   | |
And motor turn it still sounds like a basket drive issue too me. It sounds as if it may be what's seized up. |
Post# 810938 , Reply# 10   2/24/2015 at 14:17 (3,348 days old) by ind75k99 ()   |   | |
Is this something I can repair? How do I start? Kent |
Post# 810939 , Reply# 11   2/24/2015 at 14:53 (3,348 days old) by rp2813 (Sannazay)   |   | |
Yeah, good question. I have no idea what a basket drive is or how to get at it.
Something tells me that accessing it would involve a major tear-down. You may want to retrace your steps on the easier items first, considering the washer was behaving OK before you installed the new motor. Are you sure the specs for the new motor's drive mechanism are identical to the old one? |
Post# 810943 , Reply# 12   2/24/2015 at 15:33 (3,348 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 810957 , Reply# 13   2/24/2015 at 17:15 (3,348 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 811741 , Reply# 14   3/1/2015 at 11:40 (3,343 days old) by smoochies189 (vero beach)   |   | |
