Thread Number: 59516
/ Tag: Modern Dryers
Maytag Neptune Dryer Intermittent no heat problem |
Post# 821174   4/27/2015 at 15:38 (3,287 days old) by moparwash (Pittsburgh,PA )   |   | |
Before I run out and replace thermostats and gas coils willy-nilly, I thought Id run it here first:
This happens on timed and auto-dry cycles Sometimes no heat when starting Sometimes heat goes out while running Sometimes it has heat all the time The heat is really hot...much hotter than its DG108 neighbor And its just 20 days out of warranty from the used appliance place I bought it from!! |
Post# 821205 , Reply# 1   4/27/2015 at 19:55 (3,286 days old) by Gefilterflo (Newark, Ohio)   |   | |
Post# 821438 , Reply# 2   4/29/2015 at 12:26 (3,285 days old) by redcarpetdrew (Fairfield, CA)   |   | |
You should be able to open the front panel and watch it run to observe. If the igniter comes on then goes out without the gas lighting, then you most likely have bad coils or the wire connectors at the coils might be loose. If the igniter does not come on, then you might have an issue with that, the flame sensor or maybe a thermostat...
RCD |
