Thread Number: 65763
I purchased Older top of the line GE pair |
Post# 883279 , Reply# 1   6/2/2016 at 14:53 (2,884 days old) by pulltostart (Mobile, AL)   |   | |
Glad to see that they were snagged by someone who appreciates them. The dryer appears to be a DDE9200V. You can use the link to determine the month and year that these were manufactured, based on the serial number of each. I think (others should know for sure) that the sensors for these dryers are located in the exhaust/lint filter area of the drum - should be visible after removing the lint filter.
lawrence CLICK HERE TO GO TO pulltostart's LINK |
Post# 883307 , Reply# 4   6/2/2016 at 18:53 (2,884 days old) by appnut (TX)   |   | |
Not all mini-baskets fit. Is the activator have straight vanes or are they ramped? That will determine the mini-basket. I do suspect this machine, like mine, has straight vanes. Your dryer is probably 1.5 years newer than mine and probably has slightly different functionality in relation to the temp buttons & auto dry cycles than mine. I'd love to see closeup of the side of the panel with the buttons. Where your next to top buttons says special, mine said normal heat. That button was intended for the poly/knit cycle or perm press cycle. I wonder what was special about that button vs. normal or low heat. On mine, low heat was only usable on timed dry. The color of the wording on the left side of the buttons is a visual indicator as to which cycles that button can be used for. If you haven't discovered yet, the end of cycle buzzer buzzes for a continuous 2 minutes at the end before the cycle stops. If you select extra care, that initial buzzer period is 4 minutes and then buzzes for a minute each periodically through the extra care segments of the cycle. |
Post# 883410 , Reply# 5   6/3/2016 at 15:06 (2,883 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 883449 , Reply# 6   6/3/2016 at 23:18 (2,882 days old) by delaneymeegan (Midwest)   |   | |
Post# 883506 , Reply# 7   6/4/2016 at 17:01 (2,882 days old) by Floyde (Los Angeles, CA)   |   | |
Hi Kevin: Here are the pictures. Also today I did a Load of towels and it wasn't a balanced load. I went in when it was finished and the machine had moved during the unbalanced spin. There was also a smell of burnt rubber???? |
Post# 883512 , Reply# 8   6/4/2016 at 17:58 (2,882 days old) by appnut (TX)   |   | |
Post# 884962 , Reply# 9   6/13/2016 at 17:57 (2,873 days old) by camMURRAY22 (Savannah,Georgia)   |   | |
How would the GE FF look this year if it was still being built? Would it have a bigger tub or the standard size tub? |
Post# 884968 , Reply# 10   6/13/2016 at 18:11 (2,873 days old) by Yogitunes (New Jersey)   |   | |
interesting thought....
maybe a deeper tub, by putting the motor upside down on top of the suspension bar rather than underneath...or even direct drive... dual purpose, or two separate pumps....pump out and filter flo.... odd, there was never a stacked filter flo setup.... stainless inner tub, plastic outter tub, less chance of rub/rust through... would there be an HE version, low water levels, smaller fins on the agitator, yet the filter pan would flow a concentrated detergent mixture over the load during agitation... you almost can have that now with a mini wash setting, without the mini basket.....great concentrated cleaning for items like cleaning rags...as the filter pan showers the load with detergent... |
Post# 886146 , Reply# 12   6/20/2016 at 16:26 (2,866 days old) by Floyde (Los Angeles, CA)   |   | |
Thanks in advance |
Post# 886148 , Reply# 13   6/20/2016 at 16:30 (2,866 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 886173 , Reply# 14   6/20/2016 at 18:59 (2,866 days old) by goatfarmer (South Bend, home of Champions)   |   | |
