Thread Number: 67936
Can Anyone Identify This Maytag Washer Model? |
Post# 906425 , Reply# 1   11/11/2016 at 00:06 (2,723 days old) by hippiedoll ( arizona )   |   | |
Which would make it a single speed standard capacity washer.
It only has 3 water levels; SMALL, MEDIUM, NORMAL (which would be large) Your 606 is a 2-speed, large capacity washer. It has 4 water levels; SMALL, MEDIUM, NORMAL (which is large), LARGE (which is extra large). I hope I got the model number right... :o| |
Post# 906426 , Reply# 2   11/11/2016 at 00:09 (2,723 days old) by hippiedoll ( arizona )   |   | |
Post# 906428 , Reply# 3   11/11/2016 at 00:40 (2,723 days old) by msmaiden (new england)   |   | |
Thank you for taking the time to reply. Would the transmission swap out for the broken one on my A606? |
Post# 906435 , Reply# 4   11/11/2016 at 01:27 (2,723 days old) by rp2813 (Sannazay)   |   | |
Will the transmission swap? Nope, not that one. Your machine has two speeds and the machine above has just one, as it's at the bottom of the model line. I think any other model would have a compatible transmission. The "Regular Action" and "Gentle Action" selector buttons are what you want to see on a donor machine.
Keep looking. You may regret the decision to retire your faithful Maytag after using something else. |
Post# 906515 , Reply# 7   11/11/2016 at 11:13 (2,723 days old) by msmaiden (new england)   |   | |
Here is a photo of the agitator from the ad and here is the ad itself. Hopefully it is still available, hubby is calling to see. CLICK HERE TO GO TO msmaiden's LINK on Nh Craigslist
Post# 906523 , Reply# 8   11/11/2016 at 11:50 (2,723 days old) by msmaiden (new england)   |   | |
Just called the phone number given and the number is out of service! Tried to call twice. No other contact info given |
Post# 906526 , Reply# 9   11/11/2016 at 12:09 (2,723 days old) by swestoyz (Cedar Falls, IA)   |   | |
The bottom half of the transmission in the A606 (large capacity) is shorter than the one in the A106 (std capacity), meaning the whole transmission is not a direct swap. You can pull parts from the 106 trans (top, gears, etc), but that is about it.
The A106 in the photos is from the 70's. By then the bakelite agitator was LONG gone, and the gear set was the same 63 OPM as the rest of the Maytag washer line.
Ben |
Post# 906529 , Reply# 10   11/11/2016 at 12:51 (2,723 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 906533 , Reply# 11   11/11/2016 at 13:42 (2,723 days old) by rp2813 (Sannazay)   |   | |
Never mind.
I made an assumption that seemed logical to me, but didn't qualify it with "let's wait for the experts to comment."
I guess my post in your first thread was more accurate. Maytags are like old VWs -- the guts from one will pop right into another (except when tub capacities are different, as Ben stated above). |
Post# 906564 , Reply# 12   11/11/2016 at 17:27 (2,723 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 906572 , Reply# 13   11/11/2016 at 18:35 (2,722 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This washer does have a power-fin agitator, so the agitation speed is the same as an A606. It is a standard capacity washer however so only the top of the transmission can be used on a A606 [ the top is the part that usually fails on older MT washers ]
This A106 would still have the less desirable Hot wash Warm rinse water combination, so you have to reset the water temp switch after a Hot wash fill to get the more desirable better rinsing Cold rinse. |
Post# 906583 , Reply# 15   11/11/2016 at 19:48 (2,722 days old) by peteski50 (New York)   |   | |
