Thread Number: 71164
Need some help with a older maytag, membrane switch gone dark |
Post# 941953 , Reply# 1   6/5/2017 at 19:54 (2,516 days old) by Yogitunes (New Jersey)   |   | |
well if its electric....that would be a LSE1000....time frame around 1985-89....
open the dryer door and in the upper left you will find a model tag......give me the model and serial, and I can tell you the exact date of manufacture... occasionally you would find a mother board go out on one of these......for the most part, their pretty sturdy.... just out of curiosity, unplug the unit, wait a bit, and then plug back in.....always the first thing to do.... between the two, I would keep the machine...... |
Post# 941971 , Reply# 2   6/5/2017 at 20:44 (2,516 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
My sister had the same stacked unit. The board was gone when installed and Maytag replaced it pronto. Only problem with it later was unless you shut the sliding washer lid closed tight, nothing worked. Slam it open and closed and see if it works, releases switches and it did for me when little brother guessed and it worked and continued to.
Post# 941979 , Reply# 3   6/5/2017 at 21:51 (2,516 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
There are two power cords on this machine, the one for the dryer powers the control panel, if the dryer is electric you need to be sure both sides of the line are hot.
Check the terminal connections for a burned wire where the cord connects.
There is a transformer on the floor of the dryer that takes 120 volts down to 24 volts be sure you have 24 volts coming out, if so you either have bad connection on the edge of the circuit board or a bad board. |
