Thread Number: 77512
Cleaning enamel tubs on washing machines, |
Post# 1014945   11/18/2018 at 19:54 (1,985 days old) by adam-aussie-vac (Canberra ACT)   |   | |
Hey guys, I'm wondering what would you use to clean enamel tubs and what method would you use because all of the washing machine cleaners here can only be used on stainless steel tubs and I don't want to damage anything |
Post# 1014969 , Reply# 2   11/18/2018 at 21:45 (1,985 days old) by Lorainfurniture (Cleveland )   |   | |
Most of the time the tubs are porcelain on steel. Treat it like you are cleaning glass. No abrasive stuff. Personally I use plain old degreaser or oven cleaner. I spray and come back it ten minutes and scrub it clean with a plastic bristle brush. |
Post# 1014972 , Reply# 3   11/18/2018 at 23:44 (1,985 days old) by tolivac (greenville nc)   |   | |
You would not want to use lye based oven cleaners on glass!They can etch the glass surface.Read the label on the oven cleaner--if it is lye based DON'T USE IT on the porcelain surface. |
Post# 1014975 , Reply# 4   11/19/2018 at 00:50 (1,985 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 1014982 , Reply# 5   11/19/2018 at 04:15 (1,984 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Post# 1015146 , Reply# 6   11/20/2018 at 07:28 (1,983 days old) by Helicaldrive (St. Louis)   |   | |
Vinegar and a Mr Clean Magic Eraser Pad? |
Post# 1015192 , Reply# 7   11/20/2018 at 13:25 (1,983 days old) by panthera (Rocky Mountains)   |   | |
Post# 1015293 , Reply# 8   11/21/2018 at 11:48 (1,982 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1015599 , Reply# 9   11/23/2018 at 23:55 (1,980 days old) by tolivac (greenville nc)   |   | |
YES IT WILL!!!!Concentrated lye has been used to etch glass.I did it myself.Used lye drain cleaner you buy from the grocer-I would NOT want to use lye based cleaners on glass-for the other materials its fine.also don't use lye on aluminum!!!Attacks it with vengeance! |
Post# 1015624 , Reply# 11   11/24/2018 at 09:10 (1,979 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1015692 , Reply# 12   11/24/2018 at 23:51 (1,979 days old) by tolivac (greenville nc)   |   | |
Never used oven cleaners-but read their ingredients-if it had lye-stayed away from it.Lye is nasty stuff.I won't use them.Wether it hurts porcelain or not-the stuff can hurt YOU!Lye drain cleaners are considered one of the most dangerous consumer products. |
