Thread Number: 77673
Kenmore belt-drive transmission slipping / popping out of gear in Agitate mode... |
Post# 1016889 , Reply# 1   12/5/2018 at 09:28 (1,968 days old) by Kafooty06 (washington )   |   | |
Hi David I just want to say I filled my transmission with 5w30 engine oil on my 1978kenmore washer and your right it did make a difference. IN my situation my washer was making a loud scraping sound during agitation and in spin it was noisy . The fresh oil stopped the noise it's quite now and works great.
Post# 1016894 , Reply# 2   12/5/2018 at 10:21 (1,968 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi David, you have a broken spring above the agitate gear [ inside the gear case ], the water that was in the gear case caused the spring to rust and break, unfortunately unless the water got in the gear case from the washer being submerged in more than 14" of water the washer needs a new basket drive because water is creeping through the oil seals and getting into the transmission.
Dave call or text me if you need parts or more details. John L. |
