Thread Number: 77769
very Strange problem GE model gtw485asj0ws |
Post# 1018092 , Reply# 1   12/15/2018 at 08:46 (1,971 days old) by Yogitunes (New Jersey)   |   | |
many factors as to why and how this happened....the result is you may never know...
I would call GE service center and ask if they know of the reset sequence to get this going....there may be a Q&A on their website...anything is worth a shot... or check youtube vids, as someone else may have had these issues, and offered a solution... even pull the tech sheet, just to see if there may be a correction or self diagnostic chart to open up... many of these new machines are a gamble....a good surge suppressor and keeping unplugged, dryer too, when not in use....its what I do with any digital/electronic machine... I had one machine that had to be left unplugged for a few days...as a static charge built up inside....ran fine after that.... voltage spikes and the such can cause any electronic to go haywire.... |
Post# 1018139 , Reply# 3   12/15/2018 at 17:48 (1,970 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Super may be on to something. Maybe you have a leaking fill valve and the washer is going into pump mode as it detects the water. (Now that is a genuine WAG) |
Post# 1018165 , Reply# 4   12/16/2018 at 01:38 (1,970 days old) by chetlaham (United States)   |   | |
Post# 1018267 , Reply# 5   12/17/2018 at 11:25 (1,969 days old) by deltablu (Eastern South Dakota)   |   | |
regarding this problem that has to do with plastic flash in the tub pressure chamber port. One of the symptoms is drain pump starting up on its own. CLICK HERE TO GO TO deltablu's LINK |
Post# 1018273 , Reply# 6   12/17/2018 at 12:01 (1,969 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
Post# 1018304 , Reply# 7   12/17/2018 at 14:55 (1,969 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 1018693 , Reply# 8   12/21/2018 at 07:32 (1,965 days old) by chetlaham (United States)   |   | |
