Thread Number: 77856
Maytag 806 loud agitation on gentle |
Post# 1018917 , Reply# 1   12/23/2018 at 14:02 (1,951 days old) by RP2813 (Sannazay)   |   | |
Most machines, regardless of manufacturer, are louder on the slow agitation setting. I have a Maytag A712, which is basically the same as your 806. It's louder when it's agitating slowly, and sometimes there will be a rattling noise that goes along with it, which eventually stops. Ambient temperatures are also a factor. If your machine is located in a garage or basement, you may notice it's slower to ramp up to normal agitation and may be louder before it reaches that stage. |
Post# 1018925 , Reply# 2   12/23/2018 at 15:52 (1,951 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1018927 , Reply# 3   12/23/2018 at 16:09 (1,951 days old) by akronman (Akron/Cleveland Ohio)   |   | |
I have an A108S, single speed, usually very quiet. But SOMETIMES when it's returning suds, there's some unpleasant harmonic vibration between pump, agitator, and the spline that creates a rattle something fierce. Once it gets about 1/4 of the water back in the tub, it silences. I have not found anything wrong, there's just an occasional interplay of motions motors speeds and parts that gets into a loud vibrating Maytag, then it shuts up and washes well!
Post# 1018928 , Reply# 4   12/23/2018 at 16:44 (1,950 days old) by Oliger (Indianapolis, Indiana)   |   | |
Goatfarmer, yes it does. It had a leak where the water comes in that I fixed. Dryer needs a new cord. But it washes very well! |
Post# 1018968 , Reply# 5   12/24/2018 at 07:10 (1,950 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1018983 , Reply# 6   12/24/2018 at 10:37 (1,950 days old) by Oliger (Indianapolis, Indiana)   |   | |
The suds-saver just buzzes loud. That's fine though I don't need it. |
Post# 1033146 , Reply# 7   5/19/2019 at 18:32 (1,803 days old) by oliger (Indianapolis, Indiana)   |   | |
Ok. The gentle agitation eventually makes it shut off, I don't know why. Here is a video of what it sounds like. Anybody have a guess what might be wrong? |
Post# 1033148 , Reply# 8   5/19/2019 at 18:54 (1,803 days old) by Maytag85 (Sean A806)   |   | |
Post# 1033160 , Reply# 9   5/19/2019 at 20:10 (1,803 days old) by robbinsandmyers (Conn)   |   | |
Post# 1033161 , Reply# 10   5/19/2019 at 20:14 (1,803 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi, How long will it operate on low speed agitation before it cuts off ?
If it runs less than a minute and then the motor won't run at all for a few minutes the motor is overheating and cutting off on the thermal overload.
Question : does the washer spin properly on low speed spin ?, if it works on low spin you have a bad bush-button speed selector switch, if it does not work on low spin either you have a bad motor or speed selector switch or timer, check it out.
Maytag washers and dryers always had far more unusual electrical problems than about any other company.
