Thread Number: 78025
Speed Queen 2018 TR7 impressions |
Post# 1020370 , Reply# 1   1/6/2019 at 18:16 (2,028 days old) by DADoES ![]() |
![]() 3
Post# 1020374 , Reply# 2   1/6/2019 at 18:38 (2,028 days old) by Yogitunes ![]() |
![]() 3
if this works out for you, and fits your needs....who can argue that, all the better....congrats!
the agitation has me a bit iffy.....but can't deny so far it does work and the rinsing and extraction are more effective than past models.... I like too that your dealer offered you a 30 day trial.....a chance to see if you like it or not.....can't go wrong with that... |
Post# 1020413 , Reply# 5   1/7/2019 at 06:16 (2,027 days old) by neptunebob ![]() |
Post# 1020450 , Reply# 6   1/7/2019 at 15:12 (2,027 days old) by Bmoze (Boise)   |   | |
Lorrainfurniture - Just wanted to thank you for your excellent washer reviews. They’re very informative and helpful. Almost went with the Maytag Commercial, based on your review, but wanted more flexibility with water level/load levels. |
Post# 1020463 , Reply# 7   1/7/2019 at 17:11 (2,027 days old) by dylanmitchell ![]() |
Are there any mechanical or software hacks for the TR7 and other 2018 or 2019 models that will make them perform better? SQ made significant changes but wondering if there are ways to give these full fill loads and other non-energy efficient mods that clean better.
Washing machines use pretty simple tech I'm surprised I haven't heard of folks hacking machines with laptops or Raspberry Pi's. There are some mechanical controls you'd have to figure out how to interface with and actuate but you'd think a hacked machine would be a fun project. |
Post# 1020464 , Reply# 8   1/7/2019 at 17:23 (2,027 days old) by Yogitunes ![]() |
Post# 1020973 , Reply# 10   1/12/2019 at 19:06 (2,022 days old) by LowEfficiency (Iowa)   |   | |
Sometimes it's near impossible, other times not...
Many times boards are produced in huge batches, and the manufacturer actually does provision for programming them after the fact. They do this so that they can make fixes and improvements throughout production, without having to create new hardware parts each time the software changes. This of course would be obfuscated and not known to the user or even service personnel, instead being programmed (or re-programmed) at the factory. But even if the boards WERE locked down with a permanent software load, that doesn't mean your abilities to change the machine behavior are eliminated. I say this because the software in those microcontrollers still relies on external sensors and communication with the outside world to function. So with clever manipulation of the sensor inputs, you can effect huge changes in the result, without actually changing any software. Perhaps the best example of this are the "piggyback ECUs" available for fuel-injected cars. For example, if a new module was added which intercepted the signal between the fill level sensor and the control board, and also the output signal to the fill valves, you could add a "pre-soak" function to your washer simply by telling the original controller that the tub wasn't full yet when it actually was, and shutting off the fill valves to prevent the machine from overflowing. As far as the main controller knows, you simply have low water pressure and it is taking a long time to fill, so it proceeds on until your "pre-soak" modifier decides it has soaked long enough and finally tells the controller that the tub is full. |
Post# 1093709 , Reply# 11   10/19/2020 at 10:21 (1,376 days old) by panasonicvac (Northern Utah)   |   | |
![]() 2
Recently I had the opportunity to go down to my uncle's for the weekend and I was able to use their new Speed Queen washer and dryer. Last year, he and his wife were looking for a new set to replace their Whirlpool ones that were only a couple years old because it didn't clean very well and it was tearing up their loads. I suggested to them the Speed Queen because I was really pleased with the ones that I've used and that's what they ended up getting. Sometime during that year, I've made the discovery that SQ changed their regulations on their top load washers. I was a bit worried that they got one of the TR models but shortly after getting the SQs, they seemed to be really impressed with them so I was thinking that they went with both the TC5 and DC5. But when I saw them for the very first time just last weekend, I was shocked that it was in fact a TR7 and a DR7. I still wanted to try both them out so I put a load of my clothes in there and I'm going to be very honest on here, I was completely STUNNED! I went on a four wheeling trip that same weekend and so we ended up kicking alot of dust. I didn't really expected the TR7 to clean my clothes very well because they were really dusty but man this washer blew me out of the water! I took photos of my white socks to see the results very closely and I think it cleaned just as well as our LG front loader that we have.
I don't know, I'm not an expert here but now I think the TR series is not as bad as I thought they were. I still personally would want a classic model but maybe I wouldn't feel as bad if someone gifted us a TR set for our wedding present. Anyways, just thought that I'd share my thoughts about these on here. |
Post# 1093733 , Reply# 12   10/19/2020 at 14:10 (1,376 days old) by henene4 ![]() |
![]() 11
That's considered clean? |
Post# 1093738 , Reply# 13   10/19/2020 at 14:51 (1,376 days old) by smurdle450 (California)   |   | |
Post# 1093802 , Reply# 14   10/20/2020 at 03:20 (1,376 days old) by foraloysius ![]() |
![]() 7
Post# 1093811 , Reply# 15   10/20/2020 at 06:40 (1,375 days old) by Frigilux (The Minnesota Prairie)   |   | |
![]() 2
Here's a little video comparing the "Classic Clean" and "Perfect Wash" SQ top loaders from Designer Appliances.
He admits flat out that the TR (Perfect Wash) caused controversy among SQ fans and that recent tweaks to the cycles has improved cleaning performance. As I mentioned in another thread, the wizards at SQ finally realized the cleaning performance of the TR could be improved by adding 20 minutes to the wash agitation portion of the cycle. No surprise then that the machine's cleaning score from the testing organization you love to hate showed substantial improvement from the very first TRs that came off the line back in early 2018. The video is aimed at those in the market for a top-loader, so no mention of SQ's front-loaders. post was last edited: 10/20/2020-06:56] |
Post# 1093818 , Reply# 16   10/20/2020 at 07:50 (1,375 days old) by Aquarius1984 (Planet earth)   |   | |
![]() 4
Louis in his defence he probably didn’t :
Pre treat Soak over night Fill the TL with hot water to pre heat the tub and prime the water supply Drain and refill the wash water immediately Select hot, utilising the 50c water at best from the water heater. Then probably didn’t use a TOL American detergent with the separate added extras usually required like Chlorox. Oh don’t forget some of the blame lies with the fact the machine may never have seen Affresh in its lifetime so of course that affects the final result too. 😂😂😂😂😂😂 But Louis all this is quicker and better than popping them into a self heated euro machine with our one shot one product detergent and coming back to them two hours later and spotlessly white 😜 |
Post# 1093837 , Reply# 17   10/20/2020 at 10:26 (1,375 days old) by DADoES ![]() |
![]() Just to say, the socks are probably better than they appear in the photo. White-on-white with the gray patches can throw the exposure wonky. I've tried taking before (worse condition than those) and after photos of socks and found that lighting, shadows, and exposure is tricky. I don't recall now if I abandoned the effort or did post pics here. |
Post# 1093848 , Reply# 18   10/20/2020 at 11:47 (1,375 days old) by henene4 ![]() |
But these socks are 2 or so years old. Not worn much, but still. The worst discoloration I have on a white item is in the armpits of my work under shirts and that is just deodorant residue that yellows. |
Post# 1093863 , Reply# 19   10/20/2020 at 13:22 (1,375 days old) by panasonicvac (Northern Utah)   |   | |
Hey everyone,
So the socks from the after photos are just the discoloration stains, I apologies for not mentioning that above. That's actually normal to us because we usually don't try and get those stains completely clean. And to be fair, I've had those socks for quite a while now. I just got new ones since most of my other ones had holes through them. The settings on the washer from the photo is what I used for washing my clothes. Normally I would use the warm settings for my dark clothes but since I had it mixed with my white socks, I put it on hot instead because not only my clothes were filthy but also we would use the hot settings for our white clothes, white sheets, and white cleaning rags as we find that it does the best job for that. I put it on extra rinse in case if there were any soap stains that would get on my clothes. And I used whatever was left from my Tide Mountain Spring detergent (The powdered kind). Again I'm no expert but I still feel like I want a Speed Queen that uses the old school motor, transmission, and agitator separated from the tub. |
Post# 1093900 , Reply# 20   10/20/2020 at 20:54 (1,375 days old) by GELaundry4ever ![]() |
presentation of the speed queen perfect wash series. |
Post# 1093934 , Reply# 21   10/21/2020 at 04:32 (1,375 days old) by foraloysius ![]() |
![]() 4
Alex,
Discoloration stains can be removed with the right treatment. A frontloader with a heater and a good detergent is the best way to get rid of them. Oxygen bleach plays an important role in that. But on my trips across the big pond I had good results getting dirty socks clean too in a Kenmore belt drive toploader and Tide with bleach. Perhaps you are happy with getting not all the stains out of your laundry, but personally I can't stand laundry that doesn't come totally clean. |
