Thread Number: 78081
Miele Washer Flood Protection |
Post# 1020949   1/12/2019 at 16:35 (2,022 days old) by stricklybojack (South Hams Devon UK)   |   | |
I sold the Mieles i recently bought and the new owner is getting flashing lights for drain and water inlet. The new owner insisted i run a water test before buying, a reasonable request. I did and the machine ran a load no problem. But i transported it on it’s side, and delivered without draining the washer fully. My bad. Any experience with this issue out there? |
Post# 1020966 , Reply# 2   1/12/2019 at 18:14 (2,022 days old) by Stricklybojack (South Hams Devon UK)   |   | |
This machine, w1203, predates codes. It gave the signal by simultaneously flashing the inlet fault light and drain fault light. The new owner tilted the machine forward and drained the excess water, following instructions he found on the internet. Apparently all is good now....phew! Really nice machines. The matching dryer is a bit small for my needs, but a great pair for limited space. |
Post# 1020976 , Reply# 3   1/12/2019 at 19:14 (2,022 days old) by henene4 ![]() |
My mother managed that several times while cleaning out the drain filters. Maybe warn the new owner of that as well. |
Post# 1021533 , Reply# 4   1/17/2019 at 21:39 (2,017 days old) by Launderess ![]() |
On our AEG Lavamat almost had kittens! Having never seen a washer throw such a fit wasn't prepared for the drama.
Swapping out water solenoid and not tightening things up properly caused a leak which in turn triggered flood protection system. After drying out base of machine with several towels (and tightening up the connections), had to contact AEG up north to obtain programming sequence that clears fault/resets machine. |
