Thread Number: 78115
Proud of myself--repaired my agitator dogs |
Post# 1021295   1/15/2019 at 19:50 (2,019 days old) by jamiel ![]() |
Post# 1021297 , Reply# 1   1/15/2019 at 20:02 (2,019 days old) by Stricklybojack (South Hams Devon UK)   |   | |
It’s an easy job, especially after you have do it once before. I plan to replace the dogs on three machines I currently have and plan to sell, unless they look fresh I will swap them out. Dog packs are cheap, especially by the 1/2 dozen or more. By all means lift the lid, easy and satisfying to exercise the accumulated crude. |
Post# 1021303 , Reply# 2   1/15/2019 at 20:51 (2,019 days old) by jamiel ![]() |
Post# 1021306 , Reply# 3   1/15/2019 at 21:10 (2,019 days old) by Stricklybojack (South Hams Devon UK)   |   | |
Post# 1021314 , Reply# 4   1/15/2019 at 22:09 (2,019 days old) by DADoES ![]() |
![]() The top deck does *not* lift up on DD machines, it's attached to the cabinet front/sides via screws from beneath. The entire outer cabinet is removed with the top/lid attached as the video above shows, the rear panel is left standing attached to the base and holding the console. The console anchor screws (if it has them instead of the clips) may be in a couple different locations depending on the design of it - at the back corners as the video shows, or at the front corners. Some Kenmore models have them in front but under trim pieces that snap (carefully) off. |
