Thread Number: 78133
When looking for used parts crossover rebuild questions |
Post# 1021587 , Reply# 1   1/18/2019 at 11:57 (1,924 days old) by DADoES (TX, U.S. of A.)   |   | |
280184 spinner (tub) support comes with centerpost bearing (kit 285203) already installed. WP8577376 top seal is also included (or should be, I didn't get one in one instance although SearsParts sent it when I called accordingly) but not installed as turbine oil is to be added to the centerpost bearings before placing the seal. Your parts diagram shows two top seals (#23) but it was redesigned and only one is used now. The spin tube isn't sourced separately, it's part/parcel of W10820043, which includes agitator shaft bearings and that seal already installed. It also includes a clutch band (#6) and spring (#8) but not a clutch drum. Shop all your parts to other sources (Google search on the numbers), better prices than Sears can sometimes be found. 90-weight gear oil substitutes for transmission oil. I got a qt bottle @ O'Reilly Auto Parts for $6.69. Most non-compact WP-family direct-drive washers -- WP, KM, Roper, KitchenAid, Estate, Inglis, and Maytag, Amana, Admiral when they came into play -- take the same tub/spinner/centerpost support and basket drive. |
