Thread Number: 78283
/ Tag: Modern Dryers
Whirlpool Top Filter Gas Dryer Question |
Post# 1023077   1/30/2019 at 17:09 (2,004 days old) by stricklybojack (South Hams Devon UK)   |   | |
Does one need to have a gas line hooked up to get the motor to run and the drum to turn? The older ones seem to run happily without gas, but this newer one won’t run and i don’t have a gas line i can hook it up to. Some before, during, and after, debarfing pics.. This post was last edited 01/30/2019 at 17:59 |
Post# 1023078 , Reply# 1   1/30/2019 at 17:13 (2,004 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1023082 , Reply# 2   1/30/2019 at 17:24 (2,004 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 1023088 , Reply# 3   1/30/2019 at 17:59 (2,004 days old) by Stricklybojack (South Hams Devon UK)   |   | |
Bummer. Will investigate more tomorrow. **EDIT** Dryer runs like a champ! What was it? The **ON** button is also the end-of-cycle signal switch, duh! Never under estimate user error as a fruitful avenue of inquiry. In my defense let me say as it is so common at this point, I noticed someone ran a bic pen through the dryer, (even found the damn thing), and the fumes from cleaning the blue tint from everything with Goof OFF really does a number on one’s brain function.
This post was last edited 01/30/2019 at 19:15 |
Post# 1023097 , Reply# 4   1/30/2019 at 19:24 (2,004 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1023127 , Reply# 5   1/31/2019 at 05:50 (2,003 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Denim that is washed in a cold water cycle so the excess dye rubs off on the dryer drum instead of bleeding away in the warm wash. |
Post# 1023128 , Reply# 6   1/31/2019 at 05:55 (2,003 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Denim in general... Most jeans warn that you should not sit on bright colored seating... |
Post# 1023160 , Reply# 7   1/31/2019 at 11:01 (2,003 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1023257 , Reply# 8   2/1/2019 at 05:58 (2,002 days old) by askolover (South of Nash Vegas, TN)   |   | |
