Thread Number: 78353
Direct Drive 6 pad Heavy Duty Clutch |
Post# 1023871 , Reply# 1   2/7/2019 at 10:49 (1,996 days old) by coldspot66 ![]() |
I think it can be used on mostly super capacity washers. |
Post# 1023874 , Reply# 2   2/7/2019 at 10:53 (1,996 days old) by shanenc14 (Tennessee, USA)   |   | |
Here's an old listing for my model from AJ Madison's website. It's Super Capacity Plus 3.2 cubic ft. CLICK HERE TO GO TO shanenc14's LINK |
Post# 1023875 , Reply# 3   2/7/2019 at 10:57 (1,996 days old) by coldspot66 ![]() |
![]() 2
Excellent fully featured washer. DD's have always been my favorite washers for dependability and performance for the money. |
Post# 1023883 , Reply# 5   2/7/2019 at 12:12 (1,996 days old) by Lorainfurniture ![]() |
![]() 3
The six pad clutch works on any dd washer |
Post# 1023891 , Reply# 6   2/7/2019 at 14:51 (1,996 days old) by DADoES ![]() |
Post# 1023933 , Reply# 8   2/7/2019 at 22:25 (1,995 days old) by combo52 ![]() |
![]() ALL DD washers used 6 pad clutches for the first decade or so of production, some time after they went to the ND transmissions [ 1986 ] WP decided that they did not need a 6 pad clutch since it did not have to slip that long to get the basket up to full speed because the water was usually already drained out when the washer went into spin.
Leaving out three pads was a cost cut, they used a stronger spring so it would still give enough grip. The three pad clutch is less durable so Commercial models, Catalyst and resource-saver models that had more slippage or just plain more use still got the 6 pad clutch.
If you are rebuilding a machine for yourself and you are trying to make it as good as possible I would use the 6PC.
Post# 1024002 , Reply# 9   2/8/2019 at 14:08 (1,995 days old) by sel8207 ![]() |
What's the cheapest place to get a six pad clutch? |
