Thread Number: 78454  /  Tag: Modern Automatic Washers
Speed Queen Wash Cycle Temp when using Prewash AWNE92SP
Post# 1024736   2/15/2019 at 23:58 (2,253 days old) by dylanmitchell (Southern California)
dylanmitchell's profile picture
For a 2017 SQ AWNE92SP113TW01 what temp is the wash cycle when using pre-wash? For example, if you set temp to warm and select prewash is the wash cycle warm or cold? Wondering if both washes are the selected temp or if the second wash is cold vs the selected temp.
Post# 1024749 , Reply# 1   2/16/2019 at 03:07 (2,252 days old) by henene4 (Heidenheim a.d. Brenz (Germany))
It's alternating current, the polarity reverses dozens of times a second.
The EU has reversable plugs and so dp many unearthed US appliances, so yeah, I am utmost certain that on any AC supply polarity couldn't be less of a question.
Post# 1024751 , Reply# 2   2/16/2019 at 04:30 (2,252 days old) by Launderess (Quiet Please, There´s a Lady on Stage)
Manual does not say
launderess's profile picture
So am going with whatever temp is selected for wash is also done for pre-wash.
assets.ajmadison.com/ajmadison/i...
But then again starting with hot water can set many stains/soils, so maybe pre-wash is either cold or blended warm water.
Post# 1024912 , Reply# 3   2/17/2019 at 12:41 (2,251 days old) by dylanmitchell (Southern California)
I've tested the water in pre-wash and it matches the temp set for the wash cycle. I'll have to test the wash cycle water temp next time I do a pre-wash load. Rarely use pre-wash but it's a question I had and the manual didn't answer. One of this washers nice features is it doesn't drain when you turn it off so you can fill it with any temp water turn it off then on and select any setting like pre-wash to use different temp water.
