Thread Number: 78682
LG washing machine rattle 2018 model |
Post# 1027068 , Reply# 1   3/14/2019 at 16:06 (1,961 days old) by reversomatic (east anglia,england,u.k.)   |   | |
Hi , my LG was making the same noise on the slower parts of the spin . It turned out to be the plastic pegs that secure the dampers to the tub being to loose. Mines the 8kg 1600rpm and has 3 dampers. You can tell if its this by holding the drum and rocking it back and forth gently and hear slight tapping noise.. I replaced mine with 3 Hotpoint/Indesit damper pegs they seem to be a tighter fit. That was about three years ago and still no noise. Mine was only about a year old when it started the noise and was worse at lower spin speeds. As for spin speeds, in the test cycle mine never gets above 1500rpm ! and wash temperatures are low too ,it even states in the user manual that the it may not reach the stated temperature . But having said that its had no other issues. Al in all very pleased with it. Hope this helps .
Nigel. |
