Thread Number: 78706
/ Tag: Vintage Dryers
Maytag DE806 |
Post# 1027012 , Reply# 1   3/14/2019 at 04:57 (1,870 days old) by tazz (western massachusetts)   |   | |
Post# 1027017 , Reply# 2   3/14/2019 at 07:59 (1,870 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
There are various washers, spacers and a clip ring that holds the drum shaft in a properly aligned position in the bearing housing, something is missing or not in the correct position.
Something did not get back together in the sensor circuit as well or the excess front to back play in the drum is not allowing the slip-ring and pick-up brush to stay in contact.
Hopefully you can fix it from the back but you might have to tear it all apart again.
John |
Post# 1027018 , Reply# 3   3/14/2019 at 08:21 (1,870 days old) by oliger (Indianapolis, Indiana)   |   | |
Is the dryer a halo of heat? Or is it newer? Obviously you screwed something up. Spin the drum and find out where it is scraping. Use common sense and you should be able to put it back together. |
Post# 1027101 , Reply# 4   3/14/2019 at 23:55 (1,869 days old) by bajaespuma (Connecticut)   |   | |
