Thread Number: 78752
Why so much hate for Maytag Centennials? |
Post# 1027392 , Reply# 1   3/18/2019 at 10:12 (1,957 days old) by ea56 ![]() |
Well I love my Maytag Cenntenial too. I bought an MVWC415EW from Lowe’s in Dec. 2016 and have done at least 4 to 5 loads a week, every week since without any problem or disappointment. This washer is one of the best I’ve ever owned since 1972. Its not wasteful with water, but always uses an adequate amount of water to get every load thoroughly clean and rinsed. I primarlily use the Power Wash and Deep Wash cycles. I get tap hot water on these cycles, and use hot for most loads. Every load is done in 50-60 mins, and this washer never goes out of balance either.
I think that most of the people that don’t like these washers either have never used one, or haven’t read the owners manual to understand how to properly use the machine. Also, many people can’t get past not being able to watch the wash action due to the locking lid. While I’d like to watch it in action, I’m not going to take the lid latch off to do so. As long as it does what its supposed to do, I’ll trust that there is enough action under the lid making it happen. Hope that you’ll continue to like Centennial too. Eddie This post was last edited 03/18/2019 at 14:14 |
Post# 1027401 , Reply# 3   3/18/2019 at 12:18 (1,957 days old) by ea56 ![]() |
On my machine the model number and serial number are on a sticker located on the edge of the tub opening right under the bottom edge of the lid.
Eddie
Post# 1027405 , Reply# 4   3/18/2019 at 13:18 (1,957 days old) by DE409 (Maryland)   |   | |
Thanks will check for this when I get home |
Post# 1027410 , Reply# 5   3/18/2019 at 13:41 (1,957 days old) by DADoES ![]() |
![]() The last digit of the model number is the engineering change. 0 is a "first edition," successive numbers indicate some sort of design or component change. It can be significant for obtaining correct replacement parts. The serial number is coded for the year and week of factory production, if you want to cite that to get a more accurate birthdate. |
Post# 1027417 , Reply# 6   3/18/2019 at 15:11 (1,957 days old) by imperial70 ![]() |
People don't read instructions. There is nothing wrong with your washer. You probably are using it correctly and that's why you are pleased with it. |
Post# 1027418 , Reply# 7   3/18/2019 at 15:12 (1,957 days old) by DE409 (Maryland)   |   | |
I can't find either and even the factory Energystar papers etc. only reference the BW. I know I sent in the paperwork to Maytag for warranty but they claim there's no way to search for that in their system unless I've had a warranty call (???) |
Post# 1027430 , Reply# 8   3/18/2019 at 17:42 (1,957 days old) by DADoES ![]() |
Post# 1027439 , Reply# 9   3/18/2019 at 19:27 (1,957 days old) by Combo52 ![]() |
![]() 2
![]() Whirlpool switched to this design in 2010 for all their stand alone top load washers, they build more than 5000 a day.
I think they jumped the gun with this machine many people are dissatisfied with thim even though many do like them.
People first of all don’t like the fact that the lid locks and you have to wait over a minute to open the machine when you press pause if it happens to be spinning.
People don’t like how Slowly they fill, I can Pee faster, LOL. Many users report tangling and damage to their clothing, you certainly can’t load them as heavily as you could the earlier direct drive machines and get things uniformly clean without damage.
They do spin faster that’s about the only thing good I can say about them so they do save some energy in that respect.
They’ve had a lot of repair problems with these machines mode shifters, computers, lid locks, plastic main drive pulleys and splushes and worst of all the main bearing and seal fail on them and that’s not economically repairable it costs more than you paid for the machine.
John |
Post# 1027443 , Reply# 10   3/18/2019 at 21:30 (1,957 days old) by chetlaham ![]() |
Post# 1027445 , Reply# 11   3/18/2019 at 21:54 (1,957 days old) by ea56 ![]() |
My Centennial only fills slowly when using cold water, which I never wash in. So the rinse fill is fairly slow. But the fill for a hot wash is pretty quick, and warm fill is very fast, as fast as any washer I’ve ever owned. Makes no sense conservation wise, because you’re still going to use the same amount of water, regardless of how long it takes to fill.
Nevertheless, I still like my Centennial very much. And my experience is that I can get a whole bushel laundry basket full of a mixed load in, which fills it to the top dry. And these loads come out spotless, with no damage that I’m aware of. Yes, sometimes pant legs and long shirt sleeves can tangle, but I really don’t see this as a problem. Just about every washer I’ve ever used has tangled clothes from time to time. And I can also wash king size bedspreads and comforters, and they always come out clean and well rinsed. Eddie |
Post# 1027446 , Reply# 12   3/18/2019 at 22:31 (1,957 days old) by wayupnorth ![]() |
Post# 1027447 , Reply# 13   3/18/2019 at 22:33 (1,957 days old) by combo52 ![]() |
![]() I can only guess that they are just making the cycle longer so the clothing partly soaks-clean, but to me it makes no sense I know my buddy Martin in NJ is often drilling out the restrictors in the fill valves so the machines fill faster.
One thing I often think about with some newer appliances that are supposed to save energy is that they don't think about having a washer full of hot water for almost an hour. The longer a wash cycle lasts whether a washer or a DW and the machine is hot the whole time the more heat it puts off into the home which results in more A/C run time to cope with the extra heat.
John |
Post# 1027766 , Reply# 16   3/22/2019 at 23:44 (1,953 days old) by mrsalvo ![]() |
"Why so much hate for the Maytag Centennials?" This. |
Post# 1027774 , Reply# 17   3/23/2019 at 00:57 (1,952 days old) by Maytag85 (Sean A806)   |   | |
![]() 2
I guess a lot of people didn’t like them since they had controls that were unfamiliar, and I remember most of the machines that were on the floor at Sears were KM DD top loaders, and maybe some Whirlpool models, but most people were used to the mechanical controls, and having a timer that most people were familiar with. Another reason why is they probably didn’t use enough water, and some of the Maytag Centennial washers left detergent/soap stains on their clothes, and that really got people fired up to not like the Centennial washers. WP may have worked the bugs out in the Maytag Centennial washers that were sold in 2014 and 2015, but I guess they had already got a bad reputation at that point.
Post# 1027783 , Reply# 18   3/23/2019 at 06:20 (1,952 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
these are just my toughs but just wanted to share i think in my own toughs that some are more old fashion use to the old fashion direct drive machine or old fashion agitator washers like these pic posted as a reference sometime it takes time to get use to newer technologies took me at least a good 2 to 3 years or more in my case to get use to the duet washer that my mom and i own going on there 15 year this summer lol but just wanted to share my toughs
Post# 1027796 , Reply# 19   3/23/2019 at 10:54 (1,952 days old) by DADoES ![]() |
![]() Those low-fill impeller machines typically do a reasonable job if they're simply left alone to do what they're designed to do. Many (not all) of the dissatisfied/angry users are babysitting the machines too much. Continually pausing/restarting the cycle to check what it's doing. Starting them first and tossing-in the clothes after some water is already filled, which may throw the sensing process off-kilter. Trying to get them to operate "like my old washer." They are not "your old washer" and are not designed/intended to operate as such. My parents' 81yo neighbor replaced her 20yo WP DD with a Bravos impeller machine last year. She had a discussion with me on the ins-outs of them vs. an agitator (deep-fill VMW-style) vs. finding another (used) DD, and also chatted with the salesguy. She opted for the impeller. I haven't had an in-depth discussion with her after the purchase but she did say that she likes it just fine "after I learned to use it." |
Post# 1027803 , Reply# 20   3/23/2019 at 13:00 (1,952 days old) by ozzie908 ![]() |
![]() 3
Post# 1027958 , Reply# 21   3/25/2019 at 10:21 (1,950 days old) by DADoES ![]() |
![]() This is a pair of old yard-work socks out of my AquaSmart. Large load on the designated "Whites" cycle (like the previous whites video), which runs a full-hot Eco Active fill, hot HE-level fill, then a COLD deep-fill topoff. 4 tablespoons of Persil PowerPearls, 2 tablespoons STPP, 1/3 cup chlorine bleach (in the timed dispenser). Perhaps could have gotten a little better results with Biz and the 2-hr soak option. |
Post# 1027960 , Reply# 22   3/25/2019 at 11:00 (1,950 days old) by combo52 ![]() |
Post# 1027962 , Reply# 23   3/25/2019 at 11:11 (1,950 days old) by DADoES ![]() |
![]() Yes, John, I agree. Just an example that the AS can do a reasonable job. I haven't yet tried that sort of soil level on the HE regular or heavy cycle ... but regular HE works nicely on the shirts as above (incl a bit of mustard and greasy stains). The AS in deep-fill mode does use considerably more water than the Calypso. Probably also comparatively more in HE mode since there's a minimum level required to float the basket. |
Post# 1027963 , Reply# 24   3/25/2019 at 11:19 (1,950 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Hey, I know “Granny” is ‘Suthun’, but I wish for somewhat better grammar, in that I only disliked everything ending in In’, as opposed to Ing...
Other than that, everything was articulate and well presented, but I just think the Rural Speech dialect in her verb tenses (I know, I use in’ but try to alternate with an ing, as I don’t like to use more than one ing, per sentence, but I think speaking publicly is different!) was too unnecessary excessive... — Dave |
